IDENTIFICAR gps
(edited by lpscolombia 06/04/2019 01:17:52)
Topic: IDENTIFICAR gps
Buen día a todos, espero que todo marche bien en sus negocios y proyectos
requiero de su apoyo para identificar marca y puerto de este dispositivo en WIALON
saludos!
  • IDENTIFICAR gps
Lps Trackers
IDENTIFICAR gps
Re: IDENTIFICAR gps
Lo he visto en algún lugar pero no recuerdo donde. Si llego a recordar te aviso. Saludos
IDENTIFICAR gps
Re: IDENTIFICAR gps
Conocido como ST-901
Con estos puertos funciona
GoSafe G91I port 20490
Rilla G19 port 20275
TK110 port 20488
y estos son los ajustes
http://notadmin.com/gps-tracker-sinotrack-st-901/#sod
List of commands for setting up and controlling the GPS tracker SinoTrack ST-901:
Add a phone number to control the device
Command: PHONENUMBER+PASSWORD+ _ +CELLNUMBER (You can bind 1, 2 or 3 cell numbers. The phone number associated with the first cell will be taken as the main one)
Example: 899977777770000 1
Change Password
Command: 777+NEWPASSWORD+OLDPASSWORD (A new password in this command and then we will take for 5555, you will need to come up with your password and use it in the commands)
Example: 77755550000
Set time zone
Command: 896+PASSWORD+E/W+zone (The designation E and W is the choice of the side of the world, relative to Greenwich: E is east, W is west. Accordingly, for Russia it is necessary to specify E, and specifically for Moscow - E03, for New York, for example, W05 and so on)
Example: 8965555W05
Selection of tracker operation mode (SMS or GPRS)
Command: 700+PASSWORD (SMS mode is activated, this mode does not use an internet connection, it is not possible to track the location of the GPS beacon on the map online, all work is done exclusively via SMS message messages. The GPS receiver of the device is operating normally, the coordinates are determined correctly)
Example: 7005555
Command: 710+PASSWORD (GPRS-mode is activated, ATTENTION! In this mode, an Internet connection is used, an additional charge may be levied by the mobile operator. In this mode, it is possible to track the location of the GPS-beacon on the map online, while the ability to work via SMS messages is saved in full)
Example: 7105555
Getting location coordinates
Command: 669+PASSWORD (In response, the device will send you the current coordinates of your location. If there is currently no connection to GPS satellites, the last recorded coordinates will be sent, and when a stable GPS signal is restored, the data will be updated in a repeated SMS)
Example: 6695555
Alternative method: Dialing the number of the SIM card installed in the GPS tracker
The content of the response SMS messages from the tracker:
- Link to Google maps with coordinates
- Date in format Date:YYYY-MM-DD (The months from January to September are indicated in one digit, for example, July - 1, and not 01)
- The time in the specified time zone at the time of determining the coordinates in the format Time:HH:MM
- Device ID
- Source alarm in the format STATE:Phone (Not sent if requested by SMS command)
- Ignition state format ACC ON/OFF (Not sent if requested by SMS command. Correct display of the parameter status is possible only when the wiring of the device is correctly connected)
- GPS satellite visibility in the format Fix:A/V (A - GPS satellites detected, V - GPS no satellites detected)
- Movement speed at the time of addressing the tracker in the format Speed:60KM/H (kilometers per hour)
- Current charge in format Bat:4 (There are 5 possible gradations of the state of charge of the battery, where 1 is the minimum charged battery and 5 is a fully charged battery)
Shake / Vibration Sensor Alarm (Indicated as SHOCK ALARM)
Command to enable: 181+PASSWORD+SHAKINGTIMEINSECONDS
Example: 18155557
Command to disable: 180+PASSWORD
Example: 1805555
Alarm on overspeed (Indicated as OVER SPEED ALARM)
Command to enable: 122+PASSWORD+_+SPEED (Speed is indicated in kilometers per hour)
Example: 1225555 110
Command to disable: 122+PASSWORD+_+0 (In this case, parameter 0 is set instead of specifying the maximum speed)
Example: 1225555 0
Configure APN AP for GPRS connection
Command: 803+PASSWORD+_+APN+_+LOGIN+_+PASSWORD (Modern SIM cards are able to accept the settings of the access point of the Internet connection automatically)
Example for Russian Megaphone: 8035555 internet gdata gdata
Example for Russian MTS: 8035555 internet.mts.ru mts mts
Example for Russian Beelain: 8035555 internet.beeline.ru beeline beeline
Setting the IP address and port of the site to send coordinates and track the location of the tracker online
Command: 804+PASSWORD+_+IP+_+PORT (The default settings are sewn SinoTrack site)
Example for site SinoTrack: 8045555 103.243.182.54 8090
Setting the time interval for sending tracker coordinates to an online monitoring server
The command to set the interval when the ignition is on: 805+PASSWORD+_+INTERVAL (The interval is specified in seconds, a value from 5 to 1800)
Example: 805555 5
The command to set the interval with the ignition off: 809+PASSWORD+_+INTERVAL (The interval is specified in seconds, a value from 5 to 1800)
Example: 8095555 60
Alarm by SMS when + 12V appears on orange ACC wire
Command to enable: 886+PASSWORD
Example: 8865555
Command to disable: 887+PASSWORD
Example: 8875555
Alarm call to the number tied to the first cell when + 12V appears on the orange ACC wire
Command to enable: 888+PASSWORD
Example: 8885555
Command to disable: 889+PASSWORD
Example: 8895555
SMS alarm when external power is cut off
Command to enable: 011+PASSWORD
Example: 0115555
Command to disable: 010+PASSWORD
Example: 0105555
Put GPS tracker to sleep mode
When the ignition is turned off and there is no movement after a specified time, the GPS module and outgoing traffic in GSM frequencies are turned off, the device will go into power saving mode. The tracker will wake up when one of the following events occurs: a shaking sensor triggered, an incoming call or an SMS message, the ignition on / voltage supply to the orange ACC wire.
Command to enable: SLEEP+PASSWORD+ _ +TIMEINTERVAL (Delay time is indicated in minutes)
Example: SLEEP5555 6
Command to disable: SLEEP+PASSWORD+ _ +0
Example: SLEEP5555 0
If after waking up the shaking has stopped - the device falls asleep again. When the device wakes up from shaking, it does not send anything and you need to set up additional alarms.
Restart tracker
Command: RESTART (There will be a restart of the device and services, all user settings are saved)
Example: RESTART
Reset tracker settings
Command: RESET
Example: RESET
Getting tracker configuration
Command: RCONF
Example: RCONF
- Device model in format ST-901
- Tracker identification number in format ID:7777777777
- Password to control the device in the format UP:5555
- Tracker control phone numbers associated with cells in format U1:89998886644, U2:, U3:
- Device operation mode in format MODE:GPRS/SMS (depending on the selected settings in paragraph 3 of this list)
- Further, the alarm list with the parameter ON, if the alarm is on, and OFF, if the alarm is turned off. DAILY - automatic daily SMS messages with coordinates; POWER ALARM - notification when external power supply is cut off; ACCSMS - SMS alert when power is applied to the orange wire; ACCCALL - call alert when power is applied to the orange wire; GEO FENCE - alarm on exit from a given geo-zone; OVER SPEED - speed alarm; VOICE - call the number from cell 1 when an alarm occurs; SHAKE ALARM - alarm when a vibration sensor is triggered; SLEEP - the status of the function "sleep mode"
- Internet connection access point settings in format APN: internet,gdata,gdata
- IP address and port settings for sending a location to an online map in format IP:103.243.182.54:8090
- The period of sending coordinates to an online map with the ignition on in seconds in format GPRS UPLOAD TIME 1:5
- The period of sending coordinates to an online map with the ignition off in seconds in format GPRS UPLOAD TIME 2:60
- Time zone in format TIME ZONE: W05
Lps Trackers
