New user I setup can not log in :(
Topic: New user I setup can not log in :(
I have a test account and have  couple of trackers on it.
I set up a new user called Steve ( no the real login name) I gave Steve manage access on the 2 trackers.
i logged out of the test account an tried to login as Steve. It said username password invaild.
Do I need to do anything else to activate the account?
Thank you!
Andrew
Re: New user I setup can not log in :(
Response Computing,
you can create new users at demo account. I've just checked and it works fine. Please check the following:
1. how you type login and password
2. if Enabled option is activated at user's properties
Developer
duig wrote:
Response Computing,
Thank you for your reply.
I tried again and found that the username is case sensitive!
Cool!
I had about the same thing .. but, with a password. I had to drop it three times.
(edited by Addison Jor G 17/10/2023 22:04:53)
In start I was having problem to log in but phenq amazon it is ok now this is login in first attempt.
