Topic: Ecodriving Implementation
Hi,
The latest ecodriving setting in unit properties is excellent. However, we are a bit in the dark as to understand how the tracker will trigger the server. This is due to the fact that the message polling from the tracker is set at a certain interval and does not include ecodriving parameters as set by wialon. Otherwise, we are just waiting for the coincident.
IMHO, there is mismatch between the tracker and the setting that prohibit the new ecodriving setting to work properly.
We believe that we MUST accommodate changes in our tracker's firmware so that it will send message to the server as soon as the ecodriving parameter/threshold is met. The ecodriving configuration shall be the exactly the same as wialon's.
Hence, we would like to apply this logic into our firmware. Please advise us on the logic or formula that you use to implement the above setting. Our main application is for trucks.
Regards
Intermodal Telematic Service Provider
