TelTonika | Door Lock
Тема: TelTonika | Door Lock
Hi Everyone,
I am trying to integrate TelTonika FM1120 for block/unblock ignition & lock/unlock doors using SMS commands. Ignition command is working well but not able to find anything about door locks.
Please help, it is very urgent.
Thanks in Advance.
Re: TelTonika | Door Lock
vachhani.gaurav There are 2 Digital Open-collector Outputs in Teltonika 1120
Depending on your vehicle model you should connect these outputs to the central locking circuit. May be you should use some external relay.
After that you can send the command from wialon (activate/deactivate output).
Viktor Yarovenko
Business Analyst
Wialon
(30/09/2016 09:56:22 отредактировано vachhani.gaurav)
yavi -
     For ignition i have attached relay with ignition & sending setdigout 00 && setdigout 11 commands.
Now for door lock can you please explain with commands & functionality.
The maim idea is the same for both of your solutions: by command from Wialon you should commutate the state of some Teltonika output.
We created special commands: activate and deactivate output.
Please see attach.
About hardware installation.
The basing idea -- you should find the description of electronic block of central locking system in your vehicle and connect the output of Teltonika to this block (using relay or without it).
Nobody can help you without detailed information about electronic circuit of your vehicle.
  • TelTonika | Door Lock
Viktor Yarovenko
Business Analyst
Wialon
I asked with some peoples, but they are not providing any such explanation that door lock/unlock with central locking & ignition on/off works together using commands.
are you trying to unlock the doors when the unblock ignition SMS is sent and then lock them again when the ignition is Off?
Phoenix Solusi
Mobile Visible Secure
