Topic: adjusting nginx files for Wialon Local
Hello
I used a Server Wialon Local.
I have a problem in adjusting nginx files, when you change the settings. After the restart nginx, back as it was.
How can I save the settings from loss.
Thank you
Hello
Thank you
Hello har225,
There is no reason to change file local.conf  because it is generated by wlocal service.
What adjustment do you want to add and where?
Thank you for your response
I want to run scripts php, on the home page.
Default installation of wialon local doesn't  include any php module.
So if you want to run php scripts on the same server do the following:
apt-get update
apt-get upgrade
apt-get install php5-fpm
nano /etc/php5/fpm/php.ini
cgi.fix_pathinfo=0
nano /etc/php5/fpm/pool.d/www.conf
listen = /var/run/php5-fpm.sock
service php5-fpm restart
nano /etc/nginx/conf.d/php.conf
server {
        listen   80;
        root /usr/share/nginx/html;
        index index.php index.html index.htm;
server_name php.lo;
        location / {
                try_files $uri $uri/ /index.html;
error_page 404 /404.html;
        error_page 500 502 503 504 /50x.html;
        location = /50x.html {
        # pass the PHP scripts to FastCGI server listening on the php-fpm socket
        location ~ \.php$ {
                try_files $uri =404;
                fastcgi_pass unix:/var/run/php5-fpm.sock;
                fastcgi_index index.php;
                fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
                include fastcgi_params.dpkg-dist;
nginx -t
service nginx restart
cat /etc/nginx/fastcgi_params.dpkg-dist
fastcgi_param  QUERY_STRING       $query_string;
fastcgi_param  REQUEST_METHOD     $request_method;
fastcgi_param  CONTENT_TYPE       $content_type;
fastcgi_param  CONTENT_LENGTH     $content_length;
fastcgi_param  SCRIPT_NAME        $fastcgi_script_name;
fastcgi_param  REQUEST_URI        $request_uri;
fastcgi_param  DOCUMENT_URI       $document_uri;
fastcgi_param  DOCUMENT_ROOT      $document_root;
fastcgi_param  SERVER_PROTOCOL    $server_protocol;
fastcgi_param  HTTPS              $https if_not_empty;
fastcgi_param  GATEWAY_INTERFACE  CGI/1.1;
fastcgi_param  SERVER_SOFTWARE    nginx/$nginx_version;
fastcgi_param  REMOTE_ADDR        $remote_addr;
fastcgi_param  REMOTE_PORT        $remote_port;
fastcgi_param  SERVER_ADDR        $server_addr;
fastcgi_param  SERVER_PORT        $server_port;
fastcgi_param  SERVER_NAME        $server_name;
# PHP only, required if PHP was built with --enable-force-cgi-redirect
fastcgi_param  REDIRECT_STATUS    200;
nano /usr/share/nginx/html/info.php
<?php
phpinfo();
Then check your php page
Hello
Thank you for your attention, now it is working.
