Suntech ST215EL
Тема: Suntech ST215EL
Can somebody send me the SMS commands for the following
Check the current status of the device
Check the current IP and port and APN
Reconfigure the unit to Wialon platform ; hope I can use the IP 193.193.165.165 & port 20875 and new APN settings
I got a request for immediate migration for 24 units
Regards
Abraham
Suntech ST215EL
Re: Suntech ST215EL
use same commands as if using sinktrack
i.e. status req
SA200CMD;XXXXXX;02;StatReq
where the  X's are the last imei  idigits
Spread the AVL- World
Suntech ST215EL
Re: Suntech ST215EL
Do you mean that I need to use the last 6 digits in the IMEI number?
Also the text StatusReq or StatReq or Status<space>req have to be used.
If in case the SIM is locked, will you get any reply. Is there any method to unlock SIM by SMS.
Regards,
Abraham
Suntech ST215EL
Re: Suntech ST215EL
yes use the last 6 digits, no space between strings.
