Enfora MT
Тема: Enfora MT
Hi,
1. Please indicate if you have support for Enfora MT mobile tracker and what is the IP and port addresses, since i can't find them in your hardware list.
2. What is the subscription cost after the trial period.
Bemas
Enfora MT
Re: Enfora MT
bemas,
1. Enfora Mini-MT is supported
2. you may request prices
Developer
Enfora MT
Re: Enfora MT
Thanks Duig,
I used below conf to setuo on my enfora:
IP 77.74.50.78
port: 20122
and set my uniq ID to the IMEI.
Yet I cant find the device on the Wailon portal.
Meanwhile whenever i changed it to enfora test server : "udpapi.enfora.com" and "1721", I could interact successfully with the device.
Right now the device is pointed to "77.74.50.78" and "20122", is there a way i can know if Wailon is receiving data from my device or where i can write some AT Command to be sure I'm online with wailon.
Bemas
Enfora MT
Re: Enfora MT
bemas,
it would be much better if you provide me your unit's ID (here or in PM)
Developer
Enfora MT
Re: Enfora MT
This is it: 011252000842561
The device is still ON
Bemas
Enfora MT
Re: Enfora MT
Any Update! Please
Bemas
Enfora MT
Re: Enfora MT
Could there be any response to these!
Bemas
Enfora MT
Re: Enfora MT
Can anyone ofer help on this request?
I have pointed the enfora to the IP and port appropriatly yes i could not see the device on Wailon portal
Bemas
Enfora MT
Re: Enfora MT
bemas, please use UDP protocol.
Enfora MT
Re: Enfora MT
Its set to UDP already.
Your response time was too slow for me and does not encourage positive decision towards your service.
Anyway I have since pointed away the device to another IP, give me time that you want to look at the traffic, I will redirect the traffic to your IP so I can begin the test.
Thanks.
Enfora MT
Re: Enfora MT
bemas, you can do it now.
Enfora MT
Re: Enfora MT
Ok, just one moment.
Enfora MT
Re: Enfora MT
bemas, do you know IP address of your tracker?
Enfora MT
Re: Enfora MT
Do you mean the IP the telco assign to it after UDP attach is made? Yes I know it.
Should I send it?
Added after    6 minuts  38 seconds:
I have redirected it your IP and port. You should see traffic coming there by now (every 60 seconds of data).
So how do I see the mapping your portal?
Enfora MT
Re: Enfora MT
bemas, yes please write IP address.
Enfora MT
Re: Enfora MT
$NETIP: "172.035.004.217","172.024.008.050","141.001.001.001"
Enfora MT
Re: Enfora MT
bemas, this is not ext IP. Can you set send interval to 2-3 seconds for detecting device?
Enfora MT
Re: Enfora MT
I have set it to 3 seconds.
Note:the device unique ID is "veh561", don't look for IMEI.
maybe that why you are not seeing it yet. Let me know if you see somethings
Enfora MT
Re: Enfora MT
OK, I see it online, so what is the problem exactly?
Enfora MT
Re: Enfora MT
Ok, I see it too now. why was it not shown before, what did you do?
Enfora MT
Re: Enfora MT
bemas, believe me, I did nothing.
May be you just put correct unique id in the unit settings.
22
Enfora MT
Re: Enfora MT
I really think so too. Thanks.
Will get back if I have further questions as I explore the functions.
23
Enfora MT
Re: Enfora MT
hi there guys anyone know how to connect enfora my-gu to this service?
24
Enfora MT
Re: Enfora MT
did u have the exact  model?
were this info not useful? (http://gurtam.com/en/gps_tracking/gps_h … =skypatrol)
some Enfora units are labeled as skypatrol (distribuitor)
Spread the AVL- World
