Wonde Proud SPT-10
Тема: Wonde Proud SPT-10
we faced a problem with the Wonderproud M7 movement sensor. sometimes it is not sensitiv enough.
Got the following info from Wondeproud:
To adjust the G-sensor value, please execute the command.
$wp+gss=0000,1
$wp+gss=0000,2
$wp+gss=0000,3
$wp+gss=0000,4
$wp+gss=0000,5
Default value is 3.
1 is the most sensitive… for your information.
We suggest you to adjust one by one..
Wolf.
Wonde Proud SPT-10
Re: Wonde Proud SPT-10
The device ID must have a 3 at the front if not it wont work  3050418376 you configure the id by changing the command $WP+UNCFG=0000,id,0000,0000,2,2,2,2
Wonde Proud SPT-10
correct and the VT200 and VT10 with 2 you are right got confused on the string
Wonde Proud SPT-10
Hi there
I an attempting to configure a SPT 10 device to track it in Wialon. To the moment I have not succeeded.
Can anyone post a list of the $WP comands that I need to set up and the variables to use?
I have used
$WP+UNCFG=0000,1112223301,0000,0     $WP+COMMTYPE=0000,1,+56951254647,,imovil.virginmobile.cl,,,193.193.165.165,20431,30,69.36.158.33
$WP+TRACK=0000,1,60,0,0,1,1,45
If someone can help, I will appreciate it a lot
Thanks for your reply
Javier
Wonde Proud SPT-10
esee пишет:
Hi there
Javier
http://cwms3000.ru/donate/NavixySPT10.php
