Coordinate jumping problem
Тема: Coordinate jumping problem
From a very long time we are facing problem due to the coordinate jump,sometime this coordinate are jumped approx 1000kms and this KMs are added to the mileage counter and in the other mileage and due to this jumping,the speed is also showing wrong sometime 250km/hr.
So please suggest to rectify this problem.
Re: Coordinate jumping problem
Hi!
Try to use Trip Detection in the unit properties dialog. It helps to avoid coordinate jumping problem.
Dmitry Posadski
Head of Wialon Implementation Team
Or try to activate filtering for message registration. But your problem should be mostly solved by hardware of course.
we face this problem typicaly if we use some bad chinese HW (there is also good chinese HW!).
We solved it by doing message filtering the HDOP value.
If HDOP is less 4 we just dont use that message.
You have to go to Unit Configuration -->advanced --> enable filtration...
Wolf
