Create Routes from Tracks
Тема: Create Routes from Tracks
Hi,
Is there any way for Routes to be created from Tracks. In Australia we have certain Routes for Heavy Vehicles to follow by law. These set routes are for governing Height, Mass and B-Double trailers.
Due to the long distances that the Heavy Vehicles travel each day (1000km +), to create Routes with the current Routing tool in Wialon, it would take a long time but if we were able to use the Tracks (as this is the same Route the drivers use each day) this would take no time at all. It would be as simple as generating a Track then saving it as a Route then we would be able to Import/Export into our clients Accounts.
Dwayne
THE NET Global Positioning Systems
2/465 Victoria St
Wetherill Park, NSW 2164 Australia
+61428628500
Re: Create Routes from Tracks
Предлагаю уточнение.
Дать возможность экспортировать трек в виде KML-файла.
И добавить импорт KML-файла при создании маршрута.
Let me update your request.
Wanted features:
1. Export tracks as KML-files.
2. Import Routes from KML-files.
KazInterSoft - www.soft.kz
помню как-то экспортировал сообщения и импортировал в геозоны, но если бы была возможность напрямую сохранять трек как геозону, было бы гораздо удобнее...
Великий и ужасный Гиоргий Каладзе
kazintersoft пишет:
Wanted features:
Kazintersoft,
Thank you for the clarification, that is exactly what I was trying to explain.
2/465 Victoria St
+61428628500
Все еще очень актуально...
EN: The option to create geofence from a track has been implemented.
RU: Реализована функция сохранения трека движения объекта в качестве геозоны.
Katerina Alexandrova
Product Manager (Mobile)
