Topic: Concox JM-VL01
I need some help
I have a JM-VL01LA. and i need to show in platform "External power voltage value".
Which parameter i must use ? I have tried " voltage", but is not working properly
I need some help
if it is not possible to show the voltage value, at least if it is on or off.
in this case which parameter should I use?
Check if there is parameter «voltage» in the data messages.
parameter «voltage» is in the data messages, but value is wrong and not modify when external power voltage is off.
Always the same (6 V)
lclaudiomello check «alarm_type», if it shows 2, which is Ext-power cut alarm. Check other parameters from the list:
https://gurtam.com/en/gps-hardware/auto … parameters
Maybe some of them work. Nevertheless, I suggest consulting with the hardware manufacturer about the non-working voltage.
