Listing existing geofences using the Wialon Python API
Тема: Listing existing geofences using the Wialon Python API
Hi,
I am new to the Wialon API and therefore the problem I have is a relatively simple one. I am currently trying to use the Python Wialon module to get a list of existing geofences and their details. Attached below is the code I used:
from wialon.api import Wialon, WialonError
from wialon import flags
try:
    wialon_api = Wialon()
    result = wialon_api.token_login(token='MYKEY')
    wialon_api.sid = result['eid']
    result = wialon_api.avl_evts()
    spec = {
        'itemId': '4096',
        'col': '[]',
    try:
        geofences = wialon_api.resource_get_zone_data(spec=spec)
        print(geofences)
    except WialonError as e:
        print(e)
    wialon_api.core_logout()
    pass
However, this resulted in the following error:
WialonError(Invalid input resource_get_zone_data (4))
What might I be doing wrong?
Thank you in advance.
Re: Listing existing geofences using the Wialon Python API
Hey
You have to pass spec directly, not as named parameter
    try:
        geofences = wialon_api.resource_get_zone_data(spec)
        print(geofences)
        print(e)
Also check If you have access to resource with id=4096. If you don't have it, you'll get Error:7
    spec = {
        'itemId': '4096',
        'col': '[]',
Thanks a lot shmi!
I did as you said but it looks like I do not have access to that resource as I get Error:7.
How to I rectify this error?
It should be said that the I am able to retrieve geofence details from the JavaScript API.
Check example below
try:
    token = 'TOKEN'
    result = wialon_api.token_login(token=token)
    # search for resources to find resource id
    params = {
        "spec": {
            "itemsType": 'avl_resource',
            "propName": 'sys_name',
            "propValueMask": '*',
            "sortType": 'sys_name',
        "flags":0x1001,
        "force": 1,
        "from": 0,
        "to": 0
    result = wialon_api.core_search_items(params)
    # list of all available resources
    print(result['items'])
    # get first available resource id
    resource_id = result['items'][0]['id']
    # use resource id to get all its geofences
    spec = {
        'itemId': resource_id,
        'col': '[]',
    try:
        print(geofences)
        print(e)
    print(e)
Thanks a lot shmi it works like a charm!
