Digital Sensors in Other Tables
(29/07/2021 17:28:33 отредактировано Fernando Brochetto)
Тема: Digital Sensors in Other Tables
Hello,
We started using lots of digital sensors in a client, but we cannot use them in reports like Trips, Engine Hours and Summary separated in the same table.
Could column of duration from digital sensors be included on these tables + mask filter?
Example:
Engine hours table columns:
Start / End / Start Location / End Location / Duration of engine (In1) / Duration of Ar Conditionating (In2) / Duration of Operation (In3)
Fernando Brochetto
Technical Support, Rastreasul
fernando@rastreasul.com.br
Re: Digital Sensors in Other Tables
Fernando Brochetto,
I am not quite sure I got your idea. We have Sensor mask field now in the Table's settings for the tables you mentioned - please see the screenshot attached
Have you tried putting the sensors you need in that field?
  • Digital Sensors in Other Tables
Maryia Paklonskaya
Wialon Business Analyst
"The important thing is not to stop questioning" (c)
Hello mapa, how are you?
Yes, using this feature you will filter the intervals, this is not what we want, we already use this features in other cases.
We need to have a column of the duration from each digital sensor of the unit, for example:
Unit have digital sensor for high RPM (a), low RPM (b), high speed with wiper on (c) and the client want a report that have the columns like the screenshot.
Fernando Brochetto
Fernando Brochetto,
So what are you saying is that you need a timeline of data from sensors? Have you tried executing Messages - Sensor values for the purpose you have described?
I think Messages - Sensor Values will fit great with the request from customes, what do you think? See the example attached
Maryia Paklonskaya
(03/08/2021 20:13:47 отредактировано Fernando Brochetto)
Hello mapa,
No, we need a column of the duration which the digital sensors were on, the digital sensors we want to appear in the table.
The screenshot I sent was a representation of how the report could be generated, for example:
In a groupement of a day, engine was on for 08:05:32, one digital sensor was on for 02:14:36, anoter was on during...
Fernando Brochetto
Fernando Brochetto,
thank you for your explanation, now I got that you needed it for a daily report. Have you tried the report table "Digital sensors"? It seems to follow all your requirements
For a table like "Trips" adding the duration for the whole day does not seem to be the perfect way of solving the problem since that report is based on the Trips, thus the whole information will be combined based on the Trips intervals.
Maryia Paklonskaya
Hello mapa,
Digital sensors can only show the duration of one digital sensor per table.
Thats why I suggested to create the columns for Summary reports too, it will consider the whole interval.
We don't have a easy way inside Wialon to verify duration of various digital sensors today, I really believe customers who have complex solutions will benefit greatly from this improvement.
Clients who have lots of sensors like air conditioning, doors,..
Clients who uses CAN bus data.
Fernando Brochetto
Fernando Brochetto
Thank you Fernando, I will create a task to solve this problem in our backlog.
К сожалению, у вас не достаточно прав для просмотра данного текста
Maryia Paklonskaya
hello mapa,
do we have any news on this?
Fernando Brochetto
Hi Fernando Brochetto,
Unfortunately no good news here.
Maryia Paklonskaya
Hellooo mapa, do we maybe have now? This request is very important in one client we are negotiating. smile
Fernando Brochetto
Unfortunately not within Q4-2021 sad
Maryia Paklonskaya
Hello mapa, we are increasingly working with digital sensors, especially when we work with CAN bus.
When we start a different project, a different solution, basecally we are always going to have the needs of using digital sensors, and creating a table for each digital sensor is time consuming, is hard to transffer every indicators into one spreadsheet.
Working with mixer trucks for example, the client wants to know how much was the percentage of the engine that the mixer was rotating. We must create engine hours report, digital sensor, transffer every data into one spreadsheet and then create the formula.
It all could be solved by this request.
The same as when we want to use CAN data about high RPM, for example, air conditionating, high engine temperature and so on.
Please, would you be able to put some priority on this demand? It will really help make it easier to bring indicators of great use to Wialon.
Fernando Brochetto
We do understand that you face challenges working with current functionality right now at Wialon. However, we have so many other features which were supported by many other partners.
I am not sure this feature should be expected to be delivered any time soon. We will keep you updated once there are any news.
Maryia Paklonskaya
Himapa, ok sad
Fernando Brochetto
