Тема: Show actual temp in notification text, not temp at trigger time
I have a customer with a narrow alarming chain for temperatures.
He is using Warning in a certain temp-frame and Alarming in a narrower temp-frame.
Warnings after 10 - 30 - 60 - 120 minutes
Alarms after 0 - 15 - 30 - 60 - 120 - 180 minutes.
When i set notifications with the relevant delay, i always get the temperature
which was triggering the notification, not the temperature at the time the mail is sent.
The current temperature would be important to see the developement of the temperature to
be able to react accordingly.
Currently this can only be done with cascaded notifications and changing unitgroups.
For this number of notifications, which are double for night and day this is a fault risc.
Possible solution:
Add a new Tag for notification text, which uses the actual temperature at the moment the notification is sent.
Usage:
Any customer who needs a correct temperature alarming.
