26
Hecterra Release Notes
Re: Hecterra Release Notes
Hecterra v2.1.3
July 9, 2020
- Improvements to reports exported to Excel
Katerina Alexandrova
Product Manager (Mobile)
27
Hecterra v2.1.4
July 14, 2020
- New option in resource settings — Cultivations at low speed — to find cultivations for machinery which moves at near-zero speed (like coffee harvesting machines).
- In selects, we added tooltips for long names.
28
Hecterra v2.1.5
July 28, 2020
- Cultivations with the asymmetrical placement of the implement
- Use the work sensor to calculate the start, end, and duration of a cultivation
29
Hecterra v2.1.6
Aug 6, 2020
- Fuel rates for cultivations in registration and reports
30
Hecterra v2.1.7
Aug 20, 2020
- Tools to measure distance and area on the map.
31
Hecterra v2.1.9
Sep 17, 2020
- Now the grouping of data can be applied in reports: by driver, operation, crop, field, or unit.
- ID of Wialon geofences has been added to API.
- New interface language — Czech.
32
Hecterra v2.2.0
Oct 1, 2020
- New ways to get fuel for cultivations: set priorities of fuel sensor types
33
Hecterra v2.2.2
Oct 20, 2020
- Improvements for reports exported to Excel (fonts enlarged, excessive text removed)
- Software calculation of the course (to provide the correct calculation of overlaps for units that do not send the course)
34
Hecterra v2.2.3
Nov 10, 2020
- New limits for time-consuming requests. Previously, only one time-consuming request was allowed per a resource at a time (search or recalculation of candidates, combining cultivations, etc.). Now many of these limits are applied to a session of a user (and not to the resource) — this allows simultaneous work of several operators within a resource. Herewith, it is not possible to manipulate the same unit or cultivation at the same time.
- New layout of the Settings page: separation of user settings from report settings.
35
Hecterra v2.2.4
Nov 19, 2020
- Autofill for fuel consumption rates when registering a cultivation
36
Hecterra v3.0.0
Dec 10, 2020
- U.S. measurement units (acres, feet, gallons, etc.) are now available in Hecterra. To set the alternative measurement system for your resource, go to Settings => Resource and choose “U.S.”
37
Hecterra v3.0.5
Jan 28, 2021
Recently, we have released a series of updates that improve your experience in Hecterra.
We have introduced new designs for:
- Cultivation page
- The selection of units on the registration page
- Approving and declining cultivations from the table of potential cultivations
- The selection of multiple drivers for a potential cultivation
- New layout of tabled reports
38
Hecterra v3.1.0
Feb 18, 2021
• Brand new functionality — consumables: now you can create lists of seeds, fertilizers, and chemicals, as well as indicate their consumption rates while registering a cultivation.
• Columns in reports became resizable.
• Now using right/left arrows you can easily flick through the dates in the calendar on the Registration page.
39
Hecterra v4.0.0
Apr 15, 2021
  • Changes in crop rotation: now it’s possible to have several crops within one year, to set a crop for several years in a row, and to assign crop rotation using dates in future.
  • The notion of ‘winter crop’ has been removed.
40
Hecterra v4.0.2
May 27, 2021
  • The top menu has been updated: Crops, Operations, Implements, and Consumables became items within the Catalogues menu.
  • Now when using the quick method to specify the current crop, it is possible to set sowing and harvesting dates manually.
  • Translation into French.
41
Hecterra v4.1.0
Jun 10, 2021
  • General table of Crop Rotation — all fields, all crops, all years on one page.
  • Now labels of the neighbouring fields (name+area) can be shown when a field is being created or edited.
  • Date format in crop rotation now depends on user settings.
42
Hecterra v4.1.1
Jun 24, 2021
  • We introduced “What’s New” window. It pops up at the login and shows brief information about new features we release. You may close the window (and then it will reappear only with the next update) or you may go deeper and read more about new possibilities or discuss them in our forum.
  • We developed a new setting to divide found candidates by work shifts — "Divide potential cultivations considering shifts". It helps to get the right intervals of work even if you don’t assign drivers in Wialon.
  • We added the Update button to the Crop Rotation page so that you could quickly load the most recent changes.
43
Hecterra v4.1.2
Jul 1, 2021
  • Now you can adjust the time for the tractor to make a turn outside the field — it can vary from 1 to 5 minutes. You may need this option to have fuel and mileage calculated more precisely.
44
Hecterra v5.0.0
Aug 17, 2021
New functionality — Campaigns. Create campaigns (e.g., Harvesting of wheat, Spraying of corn, etc.) to watch their progress and make further decisions.
More info
45
Hecterra v5.0.1
Sep 21, 2021
  • You can now save the map with fields to a PNG file.
  • The cultivation search settings now can be adjusted straight on the Registrar page. Those temporary settings will be applied during the current session.
  • When a compound cultivation is created, now it will be shown straight away so that you can check it without going to reports.
  • Sorting by any column has been added to the list of campaigns.
  • A button to refresh campaign’s progress has been added.
  • Sequence order of report types has been changed on the Reports page.
More info...
46
Hecterra v5.0.2
Oct 19, 2021
- You can now save the map with cultivations to a PNG file.
- Minor changes and bug fixes.
More info…
47
Hecterra v5.0.4
Nov 25, 2021
Now you can monitor the campaign progress directly on the Dashboard page. To add campaigns to the Dashboard, activate a special flag for them on the Campaigns page. You may add as many campaigns as you want.
More info…
48
Hecterra v5.0.7
Dec 28, 2021
• Now when you save a part of the map to a PNG file, the file name reflects its contents. For example, the file name with an image of a field includes the field name, the file name with an image of a cultivation includes the name of the field, unit, operation, and the date.
• We have also added the ability to apply the While Label option to the application logo. To order this service, contact your personal manager.
