Firmware update for Teltonika trackers through Wialon
(10/01/2020 14:39:21 отредактировано teltonika_support)
Тема: Firmware update for Teltonika trackers through Wialon
Hello
We would like to inform you that the firmware update for Teltonika trackers is now supported on Wialon! In addition, FMB and newer trackers support uploading configuration file via Wialon, as well as downloading configuration file from a device to Wialon.
Devices supporting firmware update:
FM1000 FM1100 FM1200 FM2200 FM3200 FM3300 FM3400 FM3600 FM4100 FM4200 FM5300 FM5500 FM6300 FMB630 FMA1 FMA2
Universal devices that support firmware updates, as well as updating and downloading configurations:
FM3001 FM3010 FMB001 FMB010 FMB100 FMB110 FMB120 FMB122 FMB125 FMB202 FMB204 FMB206 FMB900 FMB920 FMB962 FMB964 FMT100
You can find detailed instructions on our FTP in the Fota API section:
http://teltonika.lt/client/
Login: gurtamf
Pass: fmArt2254
And also on our WIKI website:
https://wiki.teltonika.lt/view/Updating … via_Wialon
WIKI FMB FW errata:
https://wiki.teltonika.lt/view/FMB_firmware_errata
The list of downloadable firmware is publicly available, and all users see and can use it. Basic versions of firmware have been added to this list, periodically the list will be checked and cleared of all firmware except basic ones.
Re: Firmware update for Teltonika trackers through Wialon
Note for older firmware versions on FMB series devices:
For remote updates via FOTA API, devices with firmware 01.00.32, 01.00.22 or older firmware versions must first be updated to version 01.03.13 and only then to the current version.
teltonika_support пишет:
Thank you for this post. Good luck.
good day
this site is no longer available, they could share the update to the new repository
Hello
Login: gurtamf
Pass: fmArt2254
WIKI FMB FW errata:
Lps Trackers
Alguien tiene la URL que si funcione?
Necesito actualizar varias unidades.
omendez пишет:
x2
Telematic Servicios de Localización
www.telematic.com.mx
Please!!!
Lps Trackers
