Callback Closure
Topic: Callback Closure
Hallo
I need a ‘for’ loop to build an array of all the units with custom sensor values, which means more than one callback is scheduled which is not completed in the same loop iteration.  I know I need some sort of ‘callback closure’ here, but I don’t know how to implement it with the MessagesLoader.loadInterval method.  Could you please assist?
My code below:
function loadMessages(units) {
    var sess = wialon.core.Session.getInstance();
    var to = sess.getServerTime(); // get ServerTime
    var from = to - 300; // 5 minutes
    var ml = sess.getMessagesLoader();
    for (var i = 0; i < units.length; i++) {
        var unitId = units(i).unitId;
    const temp = ml.loadInterval(unitId, from, to, 0, 0, 10,
            function (code, data) { // loadInterval callback
                if (code) { msg(wialon.core.Errors.getErrorText(code)); return; } // exit if error code
                else {
                    let custSensorValues = [];
                    for (var i = data.messages.length - 1; i > 0; i--) { // get last received message with values
                        if (data.messages(i).p.data_type === "E6") { // E6 = custom sensor values??
                            let custSensorValue = {};
                            custSensorValue.t11p = (data.messages(i).p.t11_pressure * 0.0689475729).toFixed(2);
                            custSensorValue.t14p = (data.messages(i).p.t14_pressure * 0.0689475729).toFixed(2);
                            custSensorValues.push(custSensorValue);
                            units(i).custSensorValues = custSensorValues;
Thank you in advance.
Callback Closure
Re: Callback Closure
Easiest way to execute async operations in sequental order is to use Promises.
I wrapped messageLoader.loadInterval with function, that returns promise, added async to loadMessages and then we can use await on loadIntervalAsync to wait for request finish:
const API_ERROR = 'API_ERROR';
main().catch((error) => {
    if (error.type === API_ERROR) {
        let reason = error.fullError && error.fullError.reason;
        msg(
            wialon.core.Errors.getErrorText(error.code) +
                (reason ? ' ' + reason : ''),
    } else {
        msg('See more detailed error in console: ' + error);
        console.error(error);
async function main() {
    await loadMessages(units);
    // There you can use `custSensorValues`
async function loadMessages(units) {
    var timeTo = sess.getServerTime(); // get ServerTime
    var timeFrom = timeTo - 300; // 5 minutes
        var unitId = units[i].unitId;
        let data = await loadIntervalAsync(ml, {
            unitId,
            timeFrom,
            timeTo,
            loadCount: 10,
        for (var i = data.messages.length - 1; i >= 0; i--) {
            if (data.messages[i].p.data_type === 'E6') {
                    data.messages[i].p.t11_pressure * 0.0689475729
                ).toFixed(2);
                    data.messages[i].p.t14_pressure * 0.0689475729
                ).toFixed(2);
                units[i].custSensorValues = custSensorValues;
function loadIntervalAsync(messageLoader, options) {
    let {
        itemId,
        timeFrom,
        timeTo,
        flags = 0,
        flagsMask = 0,
        loadCount,
    } = options;
    return new Promise((resolve, reject) => {
        messageLoader.loadInterval(
            itemId,
            timeFrom,
            timeTo,
            flags,
            flagsMask,
            loadCount,
            (error, result) => {
                if (error) {
                    reject({ type: API_ERROR, code: error, fullError: result });
                    return;
                resolve(result);
Also I used i >= 0, not sure that you need it, but in your code first message was not processed.
Callback Closure
Many thanks!  Exactly what I needed!
Callback Closure
"Also I used i >= 0, not sure that you need it, but in your code first message was not processed."
I actually only need the very last message with custom sensor values/data. Is the way I did it the best/correct way to do it?
