Hello mapa yes I'm great, thank you! How are you?
Do you mean that the digits should be bigger in the calendar's pop up? Or we should make it possible to input time in the separate pop up?
Perhaps even changing the calendar's design, because last month I've used some excel files to copy and paste times to generate reports faster, so if it was separated, some partners would be harmed.
Do you use a tablet or mobile device and it is not convenient for you because of that?
Yes, I've already did some other suggestions because when you use laptop, its quite of difficult to do some actions in the platform, selecting hh:mm its annoying.
P.S. Did you know that by scrolling while your mouse is hovering the digits of the time - the time is changing?
Yess. But for laptops using touchpads, it doesn't change anything att all hahaha.
Please, take a look in some other designs.
						Fernando Brochetto
Technical Support, Rastreasul
fernando@rastreasul.com.br
