Min and Max values in Reports
Topic: Min and Max values in Reports
Hello,
could you extend the value of the min and max duration ?
not it has a maximum value of 2 digits for the hours, so 99 hour will be the maximun
it will really be good if we could make it 3 or 4 digits
check the attack photo
Best Regards
Re: Min and Max values in Reports
Hello Hasan hasan.ahmed,
Unfortunately, you didn't attach the screenshots. But most likely it is a matter of settings such as 'Max engine hours' and 'Max duration' in Intervals filtration (see the attached screenshot).
Indeed, in these settings, the maximum allowed number of hours is 99. However, I still can't imagine a situation where you need to use a value larger than the existing one. It seems to me that the vehicle cannot work with the ignition on for more than 90 consecutive days.
Please, give real examples when you need to specify a value greater than 99 hours when filtering.
  • Min and Max values in Reports
Nastassia Maslovskaya
Business Analyst, Wialon
dear  mana we can use the min value
for example show all vehicles with engine off for 200 hours or any other value greater than 99 hour.
there is a bug i made use of it and it almost  work can i show it here or do you need me to sent it privetly
Dear hasan.ahmed,
please, send me your examples and some screenshots to hosting@gurtam.com for a detailed review.
Thank you in advance.
