Тема: Editing closed service
Hello,
Is there any way to edit a closed service ?
Also, the starting date of "in progress" service
Hello,
Hello,
Hello,
Thank you for a new feature request!
As of now, you cannot edit "Service date" for a service in status: In progress. We have the same request from some other user that is why I suppose we will make it possible to edit it in the future.
Could you please clarify what fields you want to edit in Closed services? Please describe us your cases in order we understand why a closed service should be edited.
Mahmoud_elnemr1990 пишет:Hello,
Also, the starting date of "in progress" serviceHello,
As of now, you cannot edit "Service date" for a service in status: In progress. We have the same request from some other user that is why I suppose we will make it possible to edit it in the future.Could you please clarify what fields you want to edit in Closed services? Please describe us your cases in order we understand why a closed service should be edited.
I thought of it as a work around to bulk upload non closed services then edit it to be in progress
I also wonder why for due services if its planned to be start on specific day, why i cant set the planned time to be more than 1 day (start date and end date) , its only allowed to be 24 hours maximum (only one day)
kapa пишет:Mahmoud_elnemr1990 пишет:Hello,
Hello,
1) Could you please clarify what final result you want to reach?
Now, as I understood you want to bulk upload services and make them "In Progress", am I right?
I also wonder why for due services if its planned to be start on specific day, why i cant set the planned time to be more than 1 day (start date and end date), its only allowed to be 24 hours maximum (only one day)
2) As of now, you can set not a period but a specific one day when create a "Due" service. Could you explain why you need a period?
Mahmoud_elnemr1990 пишет:kapa пишет:Hello,
Hello,
Now, as I understood you want to bulk upload services and make them "In Progress", am I right?I also wonder why for due services if its planned to be start on specific day, why i cant set the planned time to be more than 1 day (start date and end date), its only allowed to be 24 hours maximum (only one day)
1- Yes
2- because i want to add planned service time, to plan trucks availability so planning accurate periods is important in such case .
some major repairs may take more than one day, i want fleet run reflect this
kapa пишет:Mahmoud_elnemr1990 пишет:I thought of it as a work around to bulk upload non closed services then edit it to be in progress
Hello,
1- Yes
Hello,
We will consider implementation of these features in the future as they are definitely very useful.
