Тема: Wialon Local Release Notes
In this thread we will notify you about new features and bug fixes in Wialon Local.
Update 06/06/2019
1904:
2. HW. Fixes, improvements and new equipment.
3. Script for removing default services that are no longer used, which caused duplication of services in cms;
4. The request to check for updates on the person server is transferred from GET to POST.
5. Fix for correct display of information about HW-modules and logging modules in the description of the updates available for installation on the administrator’s website and in the description of the latest installed updates;
6. Fix for the backend of the administrator site in the procedure for backing up the latest updates;
7. Refinement for a video player to enable the use of various rtmp-link formats for requesting a video stream;
8. Fix notifications for the driver in Logistics.
1804:
1. HW. Fixes, improvements and new equipment.
2. Script for removing default services that are no longer used, which caused duplication of services in cms;
3. The request to check for updates on the person server is transferred from GET to POST.
4. Fix errors when loading the monitoring site in IE11;
5. Fix sending notifications for the driver in Logistics.
1704:
1604:
1. Fix for HW "Drozd K-1 / M-1 (UDM12)".
Update 16/06/2019
1904:
1804:
1704:
Update 20/06/2019
1904:
2. Most of the admin backend requests to the lic server are transferred from GET to POST.
1804:
3. Fixed problem of incorrect display time zone with daylight saving time.
1704:
Update 27/06/2019
1904:
2. Translations and fix references to the documentation on the Administration Panel
1804:
1704:
Update 04/07/2019
1904:
1804:
2. Fix in CMS to output to the log when transferring objects from one account to another
1704:
Update 11/07/2019
1904:
1804:
1704:
Update 11/07/2019
1904:
1. HW (fixes, improvements, new equipment)
2. Fix to reports for correct display of the initial and final values of the sensors in the "Digital Sensors" table,
3. Fix to reports for correct merging of intervals in the table "Fuel flow",
4. Several fixes for correct calculation of events,
5. Refinements and optimizations by events: corrected the interval for auto-recalculation of events, added auto-disable of events, etc.,
6. Added the two-factor authorization deactivation function for the root user "wialon" on the administrator’s website,
7. Optimized the algorithm for rereading report table templates when purchasing / updating modules
1804:
1704:
Update 25/07/2019
1904:
2. Fix for displaying symbols on roads (road closed, repairs, etc.) with the Google Traffic layer activated
3. Revision for the admin site for a clearer drawing of icons
1804:
1704:
Update 08/08/2019
1904:
1. HW (fixes, improvements, new HW).
2. Fix for reports on the driver in the table "Orders".
3. Fix for displaying drivers in reports.
1804:
1. Fix for reports in the table "Fuel Traffic".
2. Fix for reports on the driver in the table " Orders".
Update 15/08/2019
1904:
2. Fix for the Administration Panel for the correct activation of Fleetrun
1804:
1. Fixes for Logistics
2. Fix in the script of the HW "Tracker TM"
Update 22/08/2019
1904:
1. HW (fixes, improvements, including GPS Week Number Rollover, new hw)
2. Fixes for Logistics
1804:
1. HW (improvements to solve the GPS Week Number Rollover problem)
1704:
2. Updated tariffs and roads for the Plato system
3. Fixes for Logistics
Update 29/08/2019
1904:
1. HW (fixes, improvements, including improvements the GPS Week Number Rollover problem, new HW)
2. Fix for the correct display the calculation of the fuel deviation from rates in the reports
3. Fix for correct filtering by mask in The Custom fields table in reports for unit group
1804:
1704:
1. Fix for Logistics
Update 05/09/2019
1904: (Install only with the update 09/06/2019)
2. The fix for the "Maximum upload file size" in the "Settings and limitations" section of the System tab.
1804:
1704:
Update 09/06/2019 (extraordinary)
For 1904, you need to install today's update along with yesterday.
Local: Wialon features
Update 12/09/2019
1904:
3. The fix in sdk (in the command to get the daylight saving time)
1804:
2. The fix in sdk (in the command to get the daylight saving time)
1704:
Update 18/09/2019
1904:
2. Improvement to improve security
1804:
1. Improvement to improve security
2. Fix for the monitoring site for the correct display of tooltips with scrolls in a specific situation
1704:
PS: Starting today, updates will be released on Wednesdays.
Update 25/09/2019
1904:
1. Fix of translations
2. Fix in the module "Routes"
1804:
2. HW (fixes, improvements, including GPS Week Number Number Rollover)
1704:
Update 02/10/2019
1904:
1. HW (fixes, improvements)
2. Fix Daylight saving time in api
1804:
1704:
Update 09/10/2019
1904:
2. Optimization of metrics on the Administration Panel
Update14/10/2019 (extraordinary)
1504:
Optimization to migrate from Wialon Pro to Wialon Local
Update 16/10/2019
1904:
2. Correction of situations when in messages there are names of parameters with unreadable characters.
3. Corrections for a better display of Arabic text in reports when exporting to pdf
1804:
1. Correction of situations when in messages there are names of parameters with unreadable characters.
Update 23/10/2019
1904:
1804:
1. Correction for displaying the text value of sensors in notifications.
Update 30/10/2019
1904:
2. Fix for correct login to the site using "Login as another user"
3. Fix for Logistics for distribute orders
Update 31/10/2019 (extraordinary)
1904:
