PHP/Gurtam ActiveX
Тема: PHP/Gurtam ActiveX
Hello,
Is it possible to connect with test account via ActiveX?
How to do that in PHP?
Best regards
Avernet
PHP/Gurtam ActiveX
Re: PHP/Gurtam ActiveX
Hi, it's possible to retrieve data from Wialon using PHP code.
While testing you can have access only to units from demo login (wialon_test), not from 30-days trial account.
Developer
PHP/Gurtam ActiveX
Do You have any example of connecting via PHP?
PHP/Gurtam ActiveX
Anyone?
PHP/Gurtam ActiveX
Probably there will be an example in PHP soon, it needs to be corrected a bit.
Developer
PHP/Gurtam ActiveX
(10/11/2011 02:09:44 отредактировано avernet)
Could I see the tutorial in its present form?
Time is very important for me because my company has to buy a GPS system in the near future and it must have the ability to integrate with existing ERP system. Wialon has great GUI but there is no information about integration...
PHP/Gurtam ActiveX
ActiveX documentation is available here
http://docs.gurtam.com/en/hosting/activex/start
Additionally, new Web API with rich functionality is developing now.
Developer
PHP/Gurtam ActiveX
(10/11/2011 16:07:21 отредактировано avernet)
This documentation is really poor...
Where I can download dll file which is needed to create COM object in PHP?
And what about PHP servers running on Linux?
PHP/Gurtam ActiveX
(11/11/2011 03:15:50 отредактировано avernet)
I have connected to Wialon to my test account on PHP running on Windows.
But we have PHP server running on Linux and we can't change it to Windows.
How to deal with it?
PHP/Gurtam ActiveX
(11/11/2011 13:57:38 отредактировано Tracking)
Here is an archive containing php class and example.
http://monitoring.tracking.by/wialon_activex_php.zip
The following items describe how to use the library:
1. While creating an instance of the class you shouldpass an array with URL parameters (inWialon Hostingversion you don't needthat), user's login and password.
Example:
array = array(    'url'          => 'https://activex.gurtam.com',
                        'login'          => 'wialon_test',
                        'password'      =>  'test'
$test = new WialonConnection($array);
2. Call "connect" function to get a list of units and their parameters.
Example:
$ test = new WialonConnection ($ array);
if (! $ test-> connect ()) / / If unable to get anything, print anerror
         echo $test->get_last_error();
3. get_unit_message function should accept UID (dynamic unit's id)which is linked to the session.
Actual session key is required to bein the SID class parameter.
Example of receiving messages:
$ msgarr = array (
                'id'               => $ _GET [uid], / / ​​This is Dynamic id
                'time_from'    => $ _GET [time_from],
                'time_to'       => $ _GET [time_to] / / Unix date time from. "time_to"can be added optionally
if (! $ test-> get_unit_message ($ msgarr))
          echo $test->get_last_error(); / / If errors are found, display them
           die ();
More details can be found in example.php file.
So far there was no need to generate reports. If you want to add them,i can help.
С уважением, Станислав Комар
TrackingSoft team.
PHP/Gurtam ActiveX
avernet, we plan to release Wialon SDK (web api/jscript api, etc) in february 2012. It will have all the possibilities to programmatically control 100% of all features that avaible on GUI now. Just wait three monthes.
PHP/Gurtam ActiveX
Function getting reports from Wialon is completed.
You can view example of using by downloading the archive withupdated library.
http://monitoring.tracking.by/wialon_ac … latest.zip
P.S. php5-curl module is required for the correct work of the library
In debian you can install it in the following way:
sudo apt-get install php5-curl
TrackingSoft team.
PHP/Gurtam ActiveX
THANKS!!
This is what I was looking for!!
THANKS A LOT!!
PHP/Gurtam ActiveX
It's great, what about other actions? I need group list and unit group list, please, just tell here what action name/parameters should be used?
PHP/Gurtam ActiveX
Tracking пишет:
Страница не найдена
Страница, к которой Вы пытаетесь получить доступ не найдена.
подпись сломали .. впрочем не удивительно
PHP/Gurtam ActiveX
Tracking пишет:
Example:
Example:
$ msgarr = array (
           die ();
Лучше один раз увидеть.... и 100 раз прочитать smile Gurtam Team
http://gurtam.com/ru/docs/user-guide/
http://gurtam.com/ru/docs/manager-guide/
http://gurtam.com/ru/docs/admin-guide/
PHP/Gurtam ActiveX
kost пишет:
Tracking пишет:
Example:
Страница не найдена
Подскажите плиз рабочую ссылку.
PHP/Gurtam ActiveX
Hi
This link seems to be broken,. Could you point me to the new location of the PHP class files?
Thanks in advance.
Tracking пишет:
Nishad Hussain Kaippally
Implementation Specialist, Middle East, Gurtam
"Computer science is no more about computers than astronomy is about telescopes."
PHP/Gurtam ActiveX
Hi,
files are posted in this topic
WebServices or connection to database
Developer
