Topic: New fields in devices properties
Hello,
Is it possible to add those 2 fields in the unit properties:
1. Serial number of device
2. ICC from Sim card
Why? so I can make massive importation of devices:
thanks
Hello,
thanks
Why they cannot be stored in Custom Fields?
Because when we make massive importation custom fields are not.
we are now adding this info in customs but adding one by one.
when massive importation I must go to each device, open and add the custom field so it is same that not making massive importation.
If you make some massive importation, it means, that you have some original file with this information. I'd like to see an example and explanations what info where you want to see. Maybe we can change its format, then you can export appropriate information into Custom fields. My email is t.kots@gurtam.com
ok, I will show via email.
thanks
We are agree with this request... This will be useful for us as well, specially Simcard ICC, (we are writing that number as "custom field").
Is there any news on this feature being possibly implemented any time soon btw?
Can you explain please how you would like to use ICCID in Wialon?
All the parameters set on General tab are used in this or that functions. But I know how ICCID can be used. If you need it just for information, then Custom field is good enough place to save it.
I would save us time to have it in the basic properties of device so we will be able to use this time to win more clients that will make Gurtam arrive to 2.000.000 objects this year!
Think in Gurtam blogger please...
