Maps with speed limit for each road
Тема: Maps with speed limit for each road
Hello Dears
Help please .our customer needs maps are supporting the name of the streets with the speed limit. so is this kind of maps available?
thanks
Re: Maps with speed limit for each road
Hello,
You can set up speed control based on limits from roads on tab "Advanced".
Please, notice, that "Use limits from roads" method is relevant only for the Gurtam Maps cartographic service.
@ Oleg Zharkovsky
zark пишет:
but I think the speed limit value for the street on the map does not appear. it only displays as notification. let take an example for our customer. if the unit moved on the street name called y. he needs on the map to display the speed limit for street y =120 so it this feature available in gutam's maps and support streets in Saudia Arabia
Hello!
Currently we don't have such labels displaying speed limits of the road.
You can propose this feature here.
Maps Specialist
Hello, zayedsaid14.
I moved your question to "feature request" so you don't have to create a new topic.
But I'd like to know what task do you want to do with this feature. Can you share more details about such feature usage?
Tatsiana Shmihelskaya
Business Analyst, Gurtam
Hi Tatsiana, we have a similar use case. The first is the customer wants the road speed limit recorded in the report so they can see the actual official road limit. The second use case is that the customer wants to set his own speed limits that may or may not be the same as the official speed limit and wants that shown on the report. I proposed that the way to do this was through modifying the Geofence groups so the group gets the speed limit and we attached the relevant geofences  that have the same limits to the group.
Regards
John
Phoenix Solusi
Mobile Visible Secure
JohnG, seems you can see this information with current functionality.
We have a column "Speed limit" in "Speedings" report. It shows the maximum allowed speed on a particular road section or in the unit properties.
This is also possible. You can create your own map with speed limits and send to our cartographers (mail to support@gurtam.com). They can attach some map formats to your service. This map may have a higher priority than the basic one.
