26
Automatic appearing objects after adding to account
Re: Automatic appearing objects after adding to account
tigerjump2016, thanks for letting us know.
Regarding stated below, what do you think a better approach taking into account your business processes?
mars пишет:
To prevent this from happening, we can suggest two approaches:
1) automatically add units created via CMS only to users who have access to these units and are selected for automatic adding when units are being created.
2) automatically add units created via CMS only to the creator (users-creator is selected when creating a unit in the Unit Properties).
Thanks,
Maria Starikova,
27
Privet,
Another thing I want to mention is an issue of storing a huge number of units in the top accounts in case of their automatic adding to users' work-lists. It seems that if this will take place top account users will have to often clean up their work lists and delete unnecessary units.
We already are experiencing this issue so for us there is not problem about it. I reported several times to support that when adding new devices they appear "alone" in our SuperAdmin in wialon interface....but nothing. So no problem about this.
Which approach is more viable from your perspective? Why?
Option 1 - If you do "2" we are in the same position; client with 15 users will have to add on every user the object....
It is quite simple from my point of view, develop things as simple tools for clients that will not waste time checking info from platform or trying to know where are the different tools to work with it. If you offer platform to optimize fleet and this tool gives more work to client they will not use it.
Complicated things scare clients.
Thanks
Locating things
28
Hello,
This option would be the better according to us:
I'm not sure if this solution will cover the "adding a unit to a unit group" then the unit will be appear on the user's work list (whom has access to that unit group). But this version would solve perfectly our needs.
Eflotta Vehicle Tracking Ltd, Hungary
www.eflotta.com
29
The second approach was installed to Beta yesterday.
We choose it as it is correspond to the recommended service structure. End user as a creator will get a new unit in the monitoring list, at the same time all his parents' users won't see any needless elements.
As for Wialon mobile, then an option to synchronize the monitoring list with web-app was added there recently. Seems, all these new features solve the discussed difficulties.
Tatsiana Shmihelskaya
Business Analyst, Gurtam
