User's Custom properties name
Тема: User's Custom properties name
Can you tell me all the custom properties names for the user... In API documentation, I can see only few properties.
    "prp":{
        "cfmt":<text>,        /* coordinates format: "0" - degrees and minutes, "1" - degrees */
        "email":<text>,        /* user e-mail */
        "msc":<text>,        /* map position after launching: "0" - by default, "1" - saved */
        "poisrv":<text>,    /* render POIs on server */
Thanks in advance
Thanks
J Prabhu
Re: User's Custom properties name
There is 150+ different custom properties and no such list.
If you want to find out the desired property, try to use Network panel in browser. Change the option, save changes and look, which property was actually changed.
Thanks rual....
Thanks
J Prabhu
