You need a language to receive the data from Wialon Retranslator or FLESPI. I'd recommend either ASP.NET or PHP. They are both decent web-programming languages.
In order to run these services you need a web-server. There are a lot of web-servers out there. The most popular and easy to use is probably Apache / httpd. Available as LAMP (Linux) or WAMP (Windows) Nginx can also be recommended - but is a bit difficult to work with.
If you are using SOAP as a protocol then it would send directly to port 80 to your webserver you can easily convert XML to JSON with built in functions in .NET or PHP.
Nishad Hussain Kaippally
Implementation Specialist, Middle East, Gurtam
"Computer science is no more about computers than astronomy is about telescopes."
