How configure Omnicomm optim Ignition
Topic: How configure Omnicomm optim Ignition
Hello everybody!!!
I recently bought a new GPS device Omnicomm Optim.  But I dont know how configurate the ignition sensor in the plataform Wialon.
AVL hardware supported by wialon there are 1166 Omnicomm Optim devices alredy installed.
Anyone knows how create the ingnition sensor on the wialon plataform?
Thanks
Hola a todos!!!
Recientemente he comprando un nuevo dispositivo GPs omnicomm optim. Pero no se como configurar el sensor de encendio en la plataforma de wialon. Los equipos soportados por wialon son 1166 Omnicomm Optim ya instalados.
Alguien sabe como crear el sensor de encendido en la plataforma de wialon?
Gracias
Re: How configure Omnicomm optim Ignition
hello,
not sure, that those settings are the same for all FW versions + you also will have to configure the device itself and ignition can be connected (usually) to several inputs of the tracker etc. etc. etc.
So there is basically a universal approach - you look over raw data from the tracker (in the messages tab) and find the parameter, create an ignition sensor, verify it and then use for all devices of that type.
In case there are difficulties with that - send us a note to support@gurtam.com and make sure to give us access + unit name and we'll try to assist you with that.
Create a bitwise sensor using right bit in flg status byte, it's a cake, and optim terminals rocks !
Spread the AVL- World
(edited by jommi 18/04/2017 17:26:03)
@small_gprs
can you explain how to create a bitwise sensor with the right bit in flg status byte?
If some parameter (e.g. "status") contain information in one of the bits (e.g. the fourth), you can use the following expression -- status:4
Please, notice, that bit number is counted not from 0, but from 1 in Wialon.
@ Oleg Zharkovsky
