Eco Driving App improvement
Topic: Eco Driving App improvement
Eco driving is sure an important characteristic of the fleet. So we continue to improve this direction. And today a new version of the Eco Driving app was released.
You can find there: some interface changes, sorting function and  search filter, and the most important - the units' group mode.
To compare driving of the units' group, you shoul make just one click to add the whole group to statistics table.
I also remind you that we added several templates with an individual set of criteria for automobiles, trucks and buses in unit's settings! So you can add criteria and get the result in the report in a few minutes. And then you can edit the settings during individual needs.
  • Eco Driving App improvement
Tatsiana Kots
Ex-Business Analyst, Gurtam
Re: Eco Driving App improvement
Hi tata,
Great feature by the way.
I have a  question, one of our team was "playing" with the the Unit settings and added Eco Driving to a unit. It was a truck, however he selected Automobile,
He went in to change his selection to Truck instead but not sure if it changed it or just added parameters for both?
What happens in this kind of case, as when you go back in to view unit setting and select Eco Driving - the dropdown box selection is always defaulted to Automobile, rather than what has been set?
So there is no way that we can see in order to confirm which of the 3 options has been selected....
See attached image.
Thanks.
Onwards and Upwards!!
Hi, FleetPursuit! Thanks for your feedback!
The idea of this templates is to make Eco setiings easier. This templates are based on real data, but they may not fit perfectly to your truck. So it's supposed, that you will correct criteria after using. Since that time there is no any sense to compare your data with templates.
Tatsiana Kots
Yes, thank you tata.
My question is, as there are 3 template options once you select one, in this case add Truck template you save changes to unit.
When you open up the same unit setting and go to Eco Driving it shows the parameters that are their from when it was saved, however the box at the top where template option was first chosen (Truck) it only ever shows Automobile.
In other words there is no way to know which template is in fact being used? So we don’t really know for sure which chosen template we are testing.
I hope this explains my question better.
Thanks, it's clear. We'll see how to solve it
Tatsiana Kots
The new version of EcoDriving was released today.
We added the button to clear the list of elements.
And now can you visualize trips and violations not only for cars but also for your drivers.
Tatsiana Kots
(edited by jhdeguate 31/08/2017 16:45:05)
Tata this is awesome... We will test it and come back to you with feedback..
Thanks a lot G-Team...
(2 minutes later...)
We found the first "issue":  for spanish language can you change label "Conducteurs" to "Conductores"...
Thanks!
Hello Tata...
Request # 2:
Can you include "Google Maps layers" in Eco Driving? As it will help us A LOT, specially with Satellite/Hybrid layers.
Hope you are agree with me!
Best regards...
The request is accepted. However, if it is implemented, it will be available only for the EcoDriving, that is placed on custom DNS, as maps are always bound with DNS-es and each client should have his own map key
Tatsiana Kots
(edited by jhdeguate 14/09/2017 05:11:39)
Hello Tata ...
There is an issue when we want to choose "drivers", there are several drivers that we cannot select (they show in gray color); see the attached picture, we marked with red squares all the drivers we cannot choose.
We choose "last month" where most of them have worked and we cannot select most of the drivers either.
Are we doing something wrong or is there an issue?
P.S. Thanks for approving the Google layers! Yes we do have custom DNS, sure it will work.
Thanks for your notice. Seems it's a bug. We'll fix it soon.
And Google layers are not approved yet, I'm sorry for misleading you. My answer meant that your proposal is clear and we will think about it.
Tatsiana Kots
The driver ranking should be customisable.
The report is too rigid
Please, check it.
Thank you once more for your activity.
Can you provide us with more information about the problems you have faced with? Maybe you just need our support team help to set Eco Driving for your cases?
Tatsiana Kots
(edited by fleetlogik 16/10/2017 16:05:18)
And Google layers are not apprved yet, I'm sorry for misleading you. My answer meant that your proposal is clear and we will think about it.
Tata- We have this same issue- unable to add drivers to list and some drivings on the list does not show activity when we know this should be. Did not notice this post before trying demonstrate this morning to customer.  Can you please advise what the status is on correction.  Also- does this affect ecodriving reports based upon drivers in monitoring?  Thank you.
fleetlogik , please, send more details to our support team, we will check your case more accurate, as our specialists couldn't find any problems by your description.
Thank you
Tatsiana Kots
Tata- development team looking into issues.
One point we discovered that may be of interest to others trying to add drivers to the list:  Note "double clicking" on the driver does not add to the work list.  You must use the "arrow" to add.  This is different behavior than unit list where either the arrow or double clicking will add the units to the work list.
Thank you -Greg
(edited by tata 19/10/2017 17:06:57)
fleetlogik , thank you! For sure, we will add double click for adding drivers to the list.
Edited: the fix is ready in the release version
Tatsiana Kots
I am very interested in using this, here are my findings:
- I would like to export this to CSV or Excel for further formatting and filtering.
- For some reason I cannot sort the results by Rank, I click the header but it doesn't actually sort by Rank, this is the same for the penalty column, The  other columns seem to work fine.
- When I try to do a check using drivers, 90% come up blank for any period of time that I choose.
odcbuilds, it's a pleasure to see your interest!
Excel report you can download from WialonHosting interface, as information for the app is taken from reports.
But we keep in mind idea to add data exporting from the app.
The sorting option on drivers tab is broken, thank you for notice. We'll fix it soon.
I cannot help you with the third issue without additional info. Please, describe it more to support@gurtam.com
Tatsiana Kots
