GuardMagic products for vehicle and vehicle fuel monitoring system.
(edited by GuardMagic 13/12/2017 11:58:57)
Topic: GuardMagic products for vehicle and vehicle fuel monitoring system.
GuardMagic products for vehicle and vehicle fuel monitoring system:
- Vehicle and vehicle fuel monitoring: GuardMagic VF2 (VF2m), GuardMagic VB6, (VB6lite), GuardMagic VB7 (VB7lite) modules.
Support digital fuel level sensors (3 and more sensors). Different functionality. Multi tanks support
- Road fuel tanker and fuel trailer monitoring: GuardMagic VB8 (VB8m), GuardMagic VTS1 modules.
Support up to 6 .. 11 cargo fuel compartments. Support up to 6 ..11  digital fuel level sensors and to  6 fuel quality sensors.
- Solid digital fuel level sensors for regular vehicle fuel tanks: GuardMagic DLLS1 series. EIA-485 communication interface. Sensor serial connection.
Sensor length from 300mm and up to 1500mm.
- Solid digital fuel level sensors for road fuel tanker (cargo fuel tanks): GuardMagic DLLE1ct series. Explosive proof construction. Operation with GuardMagic JBB01 safety barrier. EIA-485 communication interface. Sensor serial connection.
Sensor length from 1300mm and up to 2500mm.
Solid sensor, directly mounting in cargo fuel tank (Without any additional mechanical brackets).
- Adapter for car regular fuel level sensors: GuardMagic DAFS1m-3, GuardMagic DAFS2-m3. Directly connection to car regular resistibve type fuel level sensors. Analog inpit (also support pulse-analog signal. Analog output, RS-232 or EIA-485 output.
GuardMagic DAFS allow by very economical way embed fuel monitoring function for cars, VANs, LCV in vehicle monitoring system.
- Power Back-Up controllers: GuardMagic UBM-1, GuardMagic UBM2. For powering main modules and fuel level sensors.
Works with lead batteries.
- Trailer Identification module: GuardMagic TRIM1. EIA-485 communication interface.
- Digital temperature sensors: GuardMagic DTS2, DTS3. 1-wire communication interface, active power
www.facebook.com/GuardMagic.world/
www.instagram.com/guardmagic
www.guardmagic.com
www.tankercontrol.com
avl@guardmagic.lv
info.1@guardmagic.com
  • GuardMagic products for vehicle and vehicle fuel monitoring system.
www.guardmagic.com ;
www.tankercontrol.com;
Re: GuardMagic products for vehicle and vehicle fuel monitoring system.
GuardMagic products for Road Fuel Tanker Monitoring System:
-Solid digital fuel level sensors for road fuel tanker (cargo fuel tanks): GuardMagic DLLE1ct series. Explosive proof construction. Operation with GuardMagic JBB01 safety barrier. EIA-485 communication interface. Sensor serial connection.
- intrinsically safe barriers: GuardMagic JBB01. Independently support twoGuardMagic DLLE1ct fuel sensors. EIA-485 communication bus. (for cargo tanks with: diesel fuel, petrol, kerosene, jet fuel etc. )
www.guardmagic.com
avl@guardmagic.lv
and good support here ;-)
(edited by GuardMagic 03/01/2018 18:37:07)
GuardMagic products for fuel monitoring (fuel sensors etc):
- GuardMagic DLLS1 series fuel level sensors: ruggedised digital fuel level sensors for standard and heavy application.
For mobile and stationary application. Digital communication interface EIA-485.
Available senor length from 300mm and up to 3000mm. (one section);
For mobile application: from 300mm and up to 2500mm
for staionary objects : from 300mm and up to 3000mm
Not need any additional brackets!
- GuardMagic DLLE1ct series fuel level sensors:  ruggedised explosive proof digital fuel level sensors for standard and heavy application.
For mobile and stationary application. Digital communication interface EIA-485. Operation only with Guardmagic JBB-01 safety barrier.
Available senor length from 300mm and up to 3500mm. (One section)
For mobile application: from 1300mm and up to 2500mm (3000mm, train tank)
For stationary objects: from 1300mm and up to 3500mm
- GuardMagic DLLE2ct series fuel level sensors:  explosive proof digital fuel level sensors for standard and heavy application.
For stationary application. Digital communication interface EIA-485. Operation only with Guardmagic JBB-01 safety barrier.
Several sections.
Sensor length from 3500mm and up to 6000mm
- Guardmagic JBB-01 safety barrier.
Two channel safety barrier for GuardMagic DLLE sensor series.
Antivandal die cast aluminum enclosure.
- GuardMagic DAFS1-m3: adapter for rsistive type vehicle regular fuel level sensor.
Analog and pulse analog input. Analog output and EIA-485 communication interface.
GuardMagic DAFS2-m3: adapter for rsistive type vehicle regular fuel level sensor.
Analog and pulse analog input. Analog output and RS-232 communication interface
