Creating Sensor for Multiple Units at Once
Тема: Creating Sensor for Multiple Units at Once
Hello everyone
We have about 100 vehicles for a client that use the same device model and we would like to create a new sensor for those units. Is there a way to create this sensor for the 100 vehicles at once instead of opening each unit's properties dialogue box and creating the sensor?
That would speed up configuration tremendously. Sorry if the option is obvious but couldn't find it in documents.
Thank you for your help
Roberto
Re: Creating Sensor for Multiple Units at Once
Use export to object with Append option
Eduard Vald / GoGPS Service
www.gogps.eu
eduard.vald@gogps.eu
GoGPS пишет:
Thank you very much GoGPS, exactly what I needed wink
Have a nice day!
This copies all sensors from the source to the target units right? You can't select and copy just a single sensor.
Phoenix Solusi
Mobile Visible Secure
JohnG пишет:
Hello John
No, this doesn't copy all sensors. Both when exporting and importing, you can select which sensors to export/import. For example, you can export only one sensor, that you select among all the sensors configured on the vehicles you use for the export, or if you exported multiple sensors from the vehicle, you can choose which sensors you want to import during the import process.
Try it out, super easy. Just be careful during the import process to choose the correct Import Type: Replace, Merge or Append.
Good day!
