Тема: Truck Door Sensor with GalileoSky Devices
Dear All
Does anyone have a recommendation for a good quality, durable door sensor for cargo trucks that can be connected to GalileoSky devices (V5.0 or V2.5)?
Thank you
Dear All
Thank you
Door sensors are essentially a (digital) input switch that is activated either by a spring or magnets.
You can use any durable industrial grade door sensor switch.
Hello Nishad
That is actually what I was after: recommendation on a good supplier for these door sensor switches, as we never ordered any, preferably recommendations after first-hand experience.
Best
Nishad
ahh i never saw any truck/car which did not have a build in door sensor....
why not just connecting the existing door sensor to the tracker?
(ok, brand supernew highend manufactors use already some canbus door sensors, than you have a problem)
Wolf.
Hello Wolf
The type of trucks that the sensor would be installed on are the ones like this below in the picture. I had in mind there was no door sensor for the cargo compartment. I have to say the models are getting old already, from late 90s, early 2000s. I will see if there are no build in switches.
However there is also the case of trucks that have a permanent container on the truck bed. For those i'm sure there are no door sensors. So I would some door sensors for that case anyways.
Thanks for your help
Best
Roberto
i would just use simple chinese door contacta like them
https://www.ebay.com/sch/i.html?_from=R … p;_sacat=0
Wolf.
