User access
Тема: User access
As I can see what access a user has. Specifically how do I know if a user can run reports. view trailers, units,drivers and others. This to verify that when the user enters the app the user has the minimum required accesses to use it.
User access
Re: User access
Login to the parent account.
From the Users Tab select the User's User Properties by clicking on the spanner icon.
Click on Access Tab
From the top left dropdown select  Units
Select all the units you want this user to have access to.
Ensure the following checkbox is enabled
  • Query Reports or Messages
From the top left dropdown select  Resources
Select all the resources you want this user to have access to.
  • View Trailers
  • View Report Templates
  • View Drivers
  • View Geofences (If geofences are used in Reports)
Nishad Hussain Kaippally
Implementation Specialist, Middle East, Gurtam
"Computer science is no more about computers than astronomy is about telescopes."
User access
Re: User access
kaippally пишет:
Click on Access Tab
  • View Trailers
  • View Drivers
This if I know and I appreciate the clarification, now I need to know how to see these permissions when a user enters my app. Through SDk
User access
Re: User access
cerpas, you can get access flags of current user to some item using SDK JS by calling function getUserAccess() over your item.
I.e. unit.getUserAccess()
User access
Re: User access
deal пишет:
Thank you
With remote APi Who i can get this?
User access
Re: User access
Wialon  Flag can be calculated  fairly easily.
Here is a spreadsheet that shows the conversion and decimal equivalent of the values.
Add up all the values in decimal and you will get the ACL.
Items access rights check
Опубликовать вложения
Иконка вложений ebd540a9b4e5ea89dad5207685aca475[1] 18.92 Кб, файл был скачан 352 раз(а)
User access
Re: User access
thank you for all, but i do not open the file, File does not have extension.
User access
Re: User access
Hmm interesting.
