GeoFence Notifications with GeoFence Groups or Multiple GeoFence
(06/10/2016 17:16:23 отредактировано eplaczek)
Тема: GeoFence Notifications with GeoFence Groups or Multiple GeoFence
Hello,
We would like to add support for Notifications with GeoFence Groups or Multiple GeoFence so that the notification can recognize which Zone Exit occurred in the notification % ZONE %.
Currently this does not work, it will fill the notification with the %Zone% because it cannot determine which Zone exited.
Eric
Re: GeoFence Notifications with GeoFence Groups or Multiple GeoFence
I think there is some kind of mistake. The system really can determine which geofence was entered. The prob!em exists only when unit leaves geofence.
Katerina Alexandrova
Product Manager (Mobile)
Hi Alek,
Eric is talking about exit/leaving geofence, not enter (enter works fine).
Is there a solution for this issue yet?
What about the possibility of another text option %ZONE_LAST% which may be an easy workaround for the time being? (we know the last geofence that the unit left, as the trigger for exit geofenze is dependent on this, therefore if we can plug this zone name into the exit notification it should offer a viable option).
Thanks
Mike
michael, thank you for the idea. I think we could do something about it in the end.
I think this is an important function given a lot of other GPS system providers already support this.  I hope this can be included soon
Buen dia estimados existe ya alguna solucion a este tema, las plataformas actuales ofrecen esta herramienta sin problema el nombre de la zona de ingreso como de egreso espero se pueda solucionar esto lo antes posible ya que si es de vital importancia para los clientes obtener estos dados para sus operaciones cotidianas, podrian informarnos en que status esta esto?
We are on the way to solve this issue.
Tatsiana Shmihelskaya
Business Analyst, Gurtam
Please, try tag %ZONE% in notifications with multiple geofences. We made changes, that helps to determine from which zone (or zones) unit exited when notification triggered.
Is this available in stable or beta version of WH?
jonasf_ph , it's available in all versions of WH
