core/export_file - For user export i need more column in the excel
Topic: core/export_file - For user export i need more column in the excel
core/export_file - How to get more user columns in the exported file. what flag i need to pass to get the below values as columns in the exported excel file
1. Email Id
2. Custom fields
3. Enabled
Thanks
J Prabhu
Re: core/export_file - For user export i need more column in the excel
hi friends kindly help on this requirement
Thanks
J Prabhu
Hello
For now it can't be done with core/export_file
You can use core_search item and create file with needed columns manually
You will be able to get more dummy columns in the report template if you do this
      "l": "Driver Bindings",
      "c": "[\"unit_name\",\"time_begin\",\"location_begin\",\"time_end\",\"location_end\",\"duration\",\"duration_ival\",\"ecodriving_mark\",\"mileage\", \"dummy\", \"dummy\"]",
      "n": "drivers_group_bindings",
      "cl": "[\"Unit\",\"Beginning\",\"Initial location\",\"End\",\"Final location\",\"Duration\",\"Total time\",\"Rank\",\"Notes\",\"Mileage\",\"Custom Column 1\",, \"Custom Column 2\",]",
      "sl": "",
      "s": "",
      "f": 256,
      "sch": {
        "y": 0,
        "m": 0,
        "w": 0,
        "f1": 0,
        "f2": 0,
        "t1": 0,
        "t2": 0
      "p": "{\"grouping\":\"{\\\"type\\\":\\\"driver\\\"}\",\"fillings_params\":{},\"thefts_params\":{},\"sensors_params\":{}}"
And then using the API you can populate the columns with values.
Nishad Hussain Kaippally
Implementation Specialist, Middle East, Gurtam
"Computer science is no more about computers than astronomy is about telescopes."
