Topic: How to convert reports from PDF to EXCEL
If you need to convert reports from PDF to EXCEL please have a look at http://astar.lt/en/astar-pdf-to-excel-converter
Suppose you need to convert data from PDF to Excel with the sole purpose of importing them later in the accounting program. Should you buy Excel for this purpose? Definitely not.
Let's take another case. Suppose you have a large number of documents that need to be converted from PDF to EXCEL. Could Excel help you avoid manual work? Of course not. Obviously, you need another tool that can automate this work.
pdf2doc.com
tested and working well
Hi
you can use the following link for convert pdf to excel:
https://pdftables.com/convert-pdf-to-excel
test it.
