Topic: Teltonika FM1010
Hello,
I want to ask teltonika fm1010 obd2 tracker. Can i install fm1010 to all vehicles? Or only supported vehicles.
And which obd2 tracker is support to so many vehicle´s models?
Hello,
b.chuka Teltonika 1010 is light version of 1000 model.
1010 doesn't read CAN parameters (OBD2  data) . It  just uses OBD2 connector as power supply connector.
That's why I think that no matter which vehicle is installed this tracker. Power voltage is the same in all OBD2 connectors (as far as I know).
Hello if you still have any questions about teltonika trackers, please write me at: assistant@eljunga.com. I will gladly help you. ![]()
