Тема: wlp import failed
every time wlp import failed please give solution
Check if file contains data in needed format.
On what step do you get error?
You can send us request to support@gurtam.com with file attached and we will check.
creator is different Unit is different so that import failed. can we change through txt file ?
i have notification wlp files which is from different creator and for different hardware and unit. can i import with any changes ?
you cannot change creator of unit, you need to recreate unit again under required account
it's possible to import notification from one resource to another , but wlp file with notification's content is not the same as wlp file with unit's settings
Please write to support@gurtam.com with file attached and explain all details
