Тема: Custom Icons for Sensors
Hi everyone
We have an idea regarding Sensors and i try to explain what we need.
The idea is to add a functionality to Sensors that user can set different custom icons for different values (or different intervals) of sensor. This type of icons should be shown in Monitoring menu work-list, unit Track and in Map Output of Reports, so we except to add related option in Advanced properties of unit, Report Template properties and in Track menu (a feature like Speeding, Event or fuel filling icon). The sensor icon should be shown in case of receiving desired value from sensor (if there is 5 continues messages with same parameter value, then the set icon should be shown 5 times on map). User may have an option in sensor properties to set showing sensor icon only in case of change in sensor value (for example if there is paramx=1 in 3 continues messages and then paramx=2 in 2 next continues messages, then Wialon should shows sensor icons when value changes from 1 to 2).
I want to explain one difference between Senor Colors and Sensor Icon that we excepted. As you know it's possible to use only one sensor color in unit Track or Monitoring menu, but we except to show sensor icon from different sensors as a visualization on map or work-list. for example if we have 3 sensors with sensor icon set, then we except to see all these 3 sensors icons based on value of each sensor on unit Track on map (and the last known sensor icon in work-list).
When user hover/click sensor icon on map, a pop-up menu should display all available parameters and sensor values (like when we hover on a unit in map/work-list)
Everyone please indicate if such a function is interesting or not.
