Improvements Tracks
Topic: Improvements Tracks
Dear,
I suggest to make improvements to the generation of routes, it would be important, to have flags that indicate start and end, to give greater visibility the direction of the tracks, to use grouping options and the possibility of displaying the detail of the tracks with information.
Attachment Example images.
I hope it's useful.
Best regards,
Improvements Tracks
Re: Improvements Tracks
Adjunto Imagen
  • Improvements Tracks
Improvements Tracks
yes, some clients tell it is too heavy to go to see this info in reports:
http://prntscr.com/dcuslj
I would also add chart there.. speed, voltage, sensors, driving times...
Regards
Locating things
Improvements Tracks
aayala and locationGPS, thank you for your proposals!
Now let's summarize them.
1. Start and End points of a track can be easily reached by special blue arrow-shaped buttons in the Tracks panel (you have these buttons for each track).
2. Grouping — OK, maybe, at least we'll think about it.
3. Details about track. There is mileage there... Please, specify exactly what else you need because it's not clear from the picture.
4. Charts. For charts based on simple parameters, it's recommended to use the Messages panel instead of Tracks. For charts based on sensors, this can be provided through Reports only.
Katerina Alexandrova
Product Manager (Mobile)
Improvements Tracks
http://prntscr.com/dd4nvd
something like this is what clients wants
Locating things
Improvements Tracks
It's exactly what we have in reports.
Improvements Tracks
Hello,
In my opinion they are two different fields;
"Reports" it is clear, heavy request info with the whole info.
"Track" is used to see in a fast way the info but we see that if you add this info we request would be easier for clients to assign the load.
On report there is not the number of the stop btw. this is requested by clients...
Thanks
Regards
Locating things
Improvements Tracks
locationGPS, please specify what exact features you need in Tracks.
