hfloresh28 wrote:I mean that I need more information about the type of code that I have to use with SMS communication. I read about binary code and command methods but I don't know which one works better or which one could help me to send info to the device
 Hi
If you use a mobile phone or a GSM modem connected to your PC with a software to send SMS, then you can send commands in plain text format. The syntax is always <user> <password> Command Profile n°+ParameterID NewParameter. For example, to set the port (Parameter ID: 246) on profile 3 to the port used in Wialon for FM5500 (Port: 21309) you would send an SMS like this:
<user> <password> setparam 3246 21309
In this example:
Command = setparam
Profile n°+ParameterID = 3246
NewParameter = 21309
Never tried to send a command directly through the platform so can't help you on this side.
Best
Robert
