Тема: Temperature in Reports
Hi Gurtam Development team
There is specific items In each Report table. Most of times customers need to track sensors values in reports beside other events. It would be good if you can add Custom Sensor column in most Report Tables. In this case we can add any sensor and put it in table. For example in Rides table there is Cargo Weight but it doesn't contain Temperature Sensor, even if you add Temperature Sensor to ridesother customer may need other sensor and they should add more and more columns. But if you can only Custom Sensor we can create what the customer need and put in in reports.
Another way is to add all types of sensors column in each table!
What you think?
