Object filter
Тема: Object filter
Hello,
Is it possible to add a filter like this: http://prnt.sc/ckjarh
In the control panel?? http://prnt.sc/ckjal6
I know I can use CTRL + F and also go one by one to look for the object I need.
The idea is to make it easier for clients.
Thanks
Regards
Locating things
Object filter
Re: Object filter
You know, there's simply no space for this filter there...
Katerina Alexandrova
Product Manager (Mobile)
Object filter
Re: Object filter
Hello,
3 options,
http://prntscr.com/co4xnk
Btw, the CTRL + F only works if the groups are open and the objects are seen in the screen...
Thanks
Regards
Locating things
Object filter
Re: Object filter
locationGPS, why don't you use inbuilt Search Tool?
Object filter
Re: Object filter
Hello,
This can work...
We will test but I think it will be enough.
Thanks for info
Regards
Locating things
Object filter
Re: Object filter
Hello,
Bad news, this tool is not useful for the client;
when you look for an object it centers in the map but it is not show in the left panel.
Please check this new tool i asked for as clients with higher amount of devices are complaining.
thanks
Locating things
