Creating new Geofences based on Parkings/Stops
Тема: Creating new Geofences based on Parkings/Stops
Hello,
When creating Geofences, easiest way for clients would be from the displayed route. I did not see this tool in the SW.
The idea is to create the Geofence from a stop the route shows when displaying it in TRACKS side.
I should click on the stop icon and save the area. The area could be chosen 100 m circle, or edit directly "create geofence in this point" and have same tools than in Geofence side.
Thanks
Locating things
Re: Creating new Geofences based on Parkings/Stops
Hello!
May be now it's a little bit more steps but it's quite simple to create geofences based on Parkings/Stops from track
You just build a track with markers Stops/Parkings from Track Panel
Then go to tab Geofences and create a new circle  Geofence by double-click on Stop point
Diana Cheley
Wialon Hosting Expert
Hi,
this could work...
ok, we will try like this then.
Thanks for info!
Locating things
