Wialon Retranslator protocol
Тема: Wialon Retranslator protocol
Hello.
I need to write decoder of Wialon Retranslator Protocol. http://extapi.wialon.com/hw/cfg/WialonR … %201.0.pdf.
Everything is good except coordinates representation.
From examples in url:
A027AFDF5D984840 — lon (49.1903648)
3AC7253383DD4B40 — lat (55.7305664)
I have tried to calculate it by using this algorithm  : https://en.wikipedia.org/wiki/Double-pr … int_format
But still get for lat : 1.4957310741050529E-25.
The code is written in java.
Re: Wialon Retranslator protocol
Numbers of type double (latitude, longitude, altitude) must have little-endian bytes order. Numbers of type long, int, short (for example, speed and course) must have  big-endian bytes order.
Hi,
I have a question, how can receiving a package of Wialon Retranslator Protocol? I need to development for application in java.
farkhad.alizade
Hi,
I have a question, how can receiving a package of Wialon Retranslator Protocol? Please, some suggest.
Denisse пишет:
Hi,
Hello
In short - you have to listen port, get packages and parse them according with protocol.
Here's simple implementation on python https://gist.github.com/ashmigelski/21c … 55444c4f26
Dear
I am going to use wialon retranslator. I cannot find which port is using the wialon retranslator in local or pro version?  I need this in order to open the port at firewall rules at the server (not the receiver server)
Thanks in advance if someone could answer!
Regards
alcatraz1972 пишет:
Dear
Regards
Hello!
the default port is 20163
Diana Cheley
Wialon Hosting Expert
