How to create a unit from WLP file using javascript api in kit?
Тема: How to create a unit from WLP file using javascript api in kit?
I am trying to a unit from WLP file using javascript api in kit
I have Successfully created a unit using javascript with following code
  var name=$("#nm").val();
        var hwid=$("#hw").val();
        var sess = wialon.core.Session.getInstance();
        var user=sess.getCurrUser();
        wialon.core.Session.getInstance().createUnit(user,name, hwid,1152921504606846975,function (code,obj) { // login callback
                if (code){ alert(wialon.core.Errors.getErrorText(code)); return; }
                oid=obj.getId();
Then i tried to update the unit parameters using the following code
<!DOCTYPE html>
<html>
<head>
    <meta charset="utf-8" />
    <title>Wialon Playground - Import resource props</title>
    <script type="text/javascript" src="http://code.jquery.com/jquery-latest.min.js"></script>
    <script type="text/javascript" src="https://kit-api.wialon.com/wsdk/script/wialon.js"></script>
</head>
<body>
<style>
.btn {
  cursor:pointer;
div {
    margin-bottom:20px;
#log_cont {
    background-color: #EEEEEE;
    height: 150px;
    overflow-y: scroll;
    font-size:75%;
#log_cont table {
    width:100%;
</style>
<div id="base">
    <div>
        Append resource props to: <select id="resource" name="resource"><option value="">-- select resource --</option></select><br/>
        From file: <input class="btn" type="file" name="import_file" id="import_file"><br/>
        <input class="btn" id="btn_import_wlp" type="submit" value="Upload & Import">
    </div>
    Data to import:
    <div id="prop_types"></div>
    Log:
    <div id="log_cont">
        <table>
            <tbody id="log"></tbody>
        </table>
    </div>
</div>
<script type="text/javascript">
var importWLP = {
    // generate needed res props system data
      prop_types: {
          poi: {
              library: "resourcePois",
              dataFlag: wialon.item.Resource.dataFlag.poi,
              editFlag: wialon.item.Resource.accessFlag.editPoi,
              methodCreateItem: "createPoi",
              printName: "POIs"
          zones: {
              library: "resourceZones",
              dataFlag: wialon.item.Resource.dataFlag.zones,
              editFlag: wialon.item.Resource.accessFlag.editZones,
              methodCreateItem: "createZone",
              printName: "Geofences"
          jobs: {
              library: "resourceJobs",
              dataFlag: wialon.item.Resource.dataFlag.jobs,
              editFlag: wialon.item.Resource.accessFlag.editJobs,
              methodCreateItem: "createJob",
              printName: "Jobs"
          notifications: {
              library: "resourceNotifications",
              dataFlag: wialon.item.Resource.dataFlag.notifications,
              editFlag: wialon.item.Resource.accessFlag.editNotifications,
              methodCreateItem: "createNotification",
              printName: "Notifications"
          drivers: {
              library: "resourceDrivers",
              dataFlag: wialon.item.Resource.dataFlag.drivers,
              editFlag: wialon.item.Resource.accessFlag.editDrivers,
              methodCreateItem: "createDriver",
              printName: "Drivers"
          trailers: {
              library: "resourceTrailers",
              dataFlag: wialon.item.Resource.dataFlag.trailers,
              editFlag: wialon.item.Resource.accessFlag.editTrailers,
              methodCreateItem: "createTrailer",
              printName: "Trailers"
          reports: {
              library: "resourceReports",
              dataFlag: wialon.item.Resource.dataFlag.reports,
              editFlag: wialon.item.Resource.accessFlag.editReports,
              methodCreateItem: "createReport",
              printName: "Reports"
    init: function () {
          // flags to specify what kind of data should be returned
          var flags = wialon.item.Item.dataFlag.base;
          for (var i in this.prop_types) {
              sess.loadLibrary( this.prop_types[i].library );
            flags =  wialon.util.Number.or(flags, this.prop_types[i].dataFlag); // 64 bit OR
            $('#prop_types').append('<input type="checkbox" checked="checked" name="'+i+'"> '+this.prop_types[i].printName+'<br>');    // construct prop types checkboxes
          // Subscribe on resource data
        sess.updateDataFlags( // load items to current session
            [{type: "type", data: "avl_unit", flags: flags, mode: 0}], // Items specification
            function (code){ // updateDataFlags callback
                if (code) {
                    importWLP.log("Error: "+wialon.core.Errors.getErrorText(code));
                    return; // exit if error code
                importWLP.res = sess.getItems("avl_unit"); // get loaded 'avl_resource's items
                for (var i = 0; i < importWLP.res.length; i++) {
                    $('#resource').append('<option value="'+ importWLP.res[i].getId() +'">'+ importWLP.res[i].getName() +'</option>');
        $('#btn_import_wlp').click( function(){ importWLP.importFromFile.apply( $('#import_file')[0] ) } );
    importFromFile: function (event) {
        var res_id = $('#resource').val(),
            filter = [];
        if ( !res_id ) {
            alert('Select resource to import to');
            return false;
        $('#prop_types input[type="checkbox"]:checked').each(function(){
            filter.push( $(this).attr('name') );
        if ( !filter.length ) {
            alert('Select prop types to import');
            return false;
        alert(res_id);
        importWLP.log('Import start...');
        // this - is input type="file"
        wialon.exchange.Exchange.importJson([this], function(code, fileData){
            if (code) {
                importWLP.log('Error('+code+')');
                return;
            var res = wialon.core.Session.getInstance().getItem(res_id); // get resource by id
            var user_access = res.getUserAccess();
            // iterate through uploaded files
            wialon.core.Remote.getInstance().startBatch();
            for (var f in fileData.files) {
                // iterate through props
                for (var res_type in importWLP.prop_types) {
                    // check resProp exists and items are in array
                    if ( typeof fileData.files[f][res_type] != 'undefined' && $.isArray( fileData.files[f][res_type] ) && fileData.files[f][res_type].length ) {
                        if ( !wialon.util.Number.and(user_access, importWLP.prop_types[res_type].editFlag) ) {
                            importWLP.log('You don\'t have access to edit '+ res_type +' in ' + res.getName());
                            continue;
                        // iterate through prop items
                        for (var i in fileData.files[f][res_type]) {
                            // create needed prop
                            res[ importWLP.prop_types[res_type].methodCreateItem ]( fileData.files[f][res_type][i], function(code, data) {
                                importWLP.log('Created ' + ( (data && typeof data.n != 'undefined') ? "'" + data.n + "'" : 'prop') + ' ' + (code ? 'Error('+code+')' : 'Ok'));
            wialon.core.Remote.getInstance().finishBatch(function(){
                importWLP.log('Import completed successfully');
                $('#resource').val('');
    log: function(msg) {
        var $log = $('#log'),
            $log_cont = $('#log_cont');
        $log.append('<tr><td>' + msg + '</td></tr>');
        $log_cont.animate({
            scrollTop: $log_cont[0].scrollHeight
        }, 300);
// execute when DOM ready
$(document).ready(function () {
    wialon.core.Session.getInstance().initSession("https://kit-api.wialon.com"); // init session
    // For more info about how to generate token check
    // http://sdk.wialon.com/playground/demo/app_auth_token
    wialon.core.Session.getInstance().loginToken("xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", "", // try to login
    function (code) { // login callback
        if (code) {
            importWLP.log(wialon.core.Errors.getErrorText(code));
        importWLP.init(); // when login suceed then run init() function
</script>
</body>
</html>
but it stops while importing WLP and does not respond afterwards
Please help me with this
i am attaching the WLP file i used
Thanks
Опубликовать вложения
Иконка вложений Unit.wlp 2.96 Кб, файл был скачан 808 раз(а)
Re: How to create a unit from WLP file using javascript api in kit?
ameen, first of all You are trying to operate with resource's prop_items (zones, poi, jobs, ...) but talking about unit.
that was a code to import resources from wlp . and it works fine.
i tried to edit it and i failed to figure out how to import a unit from wlp file. sorry for misleading with that code. please help me to find out a way to import unit parameters from a wlp file and update a unit with that using js api.
thanks
(24/05/2016 16:21:35 отредактировано deal)
It is not so trivial to import unit's properties compared to resource's ones.
At first You can replace resource's propitems with unit's ones: sensors (createSensor), fields (createCustomField), afields (createAdminField), aliases (createCommandDefinition), intervals (createServiceInterval), profile (updateProfileField).
The rest of unit's properties like counters, general, hwConfig, reportProps, advProps, trip, fuel need specific realization.
counters: updateCalcFlags, updateMileageCounter, updateEngineHoursCounter, updateTrafficCounter
general: updateName, updateDeviceSettings, updateUniqueId2, updatePhoneNumber, updatePhoneNumber2, updateAccessPassword
hwConfig: updateHwParams
reportProps: updateReportSettings, updateDriverActivitySettings
advProps: updateMessagesFilter, updateCustomProperty
trip: updateTripDetector
fuel: updateFuelCalcTypes , updateFuelLevelParams, updateFuelConsMath, updateFuelConsRates, updateFuelConsImpulse
More info about each of this methods you can find in docs http://sdk.wialon.com/wiki/en/sidebar/r … /unit/unit
thank you deal
