Topic: max request per seconds
hello
is there any limit for sending pocket from a device?
for example can i send 10 pocket per second from a device or from a ip !?
hello
cant see any restrictions here: http://docs.gurtam.com/en/hosting/req/req
As i remember events to Browser are send 4x per second, so sending 10x per second makes not really sence.
And there is a 10 Mio Messages limit in Reports, so you can request only reports for ca. 11 days if sending 24/7 to get blocked with 10 Mio messages :-)
For realtime tracking you also have
-- Delay in data calculation in gps tracker
-- 200-700 ms delay in gprs signal
-- from my experience a delay of a few seconds in the whole Wialon processing.
So it would be realy interesting for what you want to send 10 locations per second...
Wolf.
i asked because i have a transaction server in my side
i receive data from about 2000 device and save them to my local database
then i send them to wialon
my tracker sent location every 30 second
so i have about 70 pocket to send to gurtam every seconds!
ok
now i see there are a 0.5 sec delay for a new request
so
how can i avoid limit or increase the request per seconds!?
Roozgar,
i think you should clarify that a bit more:
If you forward the data of 2000 units to 2000 units in Wialon, that should be no problem (if i understand the limitations correct).
(many providers are bundling a few IPV4 adresses and have millions of devices behind that NAT... so i am sure that Wialon can handle that).
And as you pay than for 2000 units in Wialon, i am sure that support@gurtam.com will help you ASAP with your task.
If you want to send 2000 units from your database into 1 Unit in Wialon i am sure there are some limitations...
Wolf.
Roozgar,
(many providers are bundling a few IPV4 adresses and have millions of devices behind that NAT... so i am sure that Wialon can handle that).And as you pay than for 2000 units in Wialon, i am sure that support@gurtam.com will help you ASAP with your task.
If you want to send 2000 units from your database into 1 Unit in Wialon i am sure there are some limitations...Wolf.
each tracker hardware send data to its own unit in wialon
so
as you explained this dont face any limitation!!
Thank you for your informationn
