GuardMagic DLLE1ct - robust fuel level sensor for road fuel tanker
(24/09/2015 14:29:26 отредактировано GuardMagic)
Тема: GuardMagic DLLE1ct - robust fuel level sensor for road fuel tanker
GuardMagic DLLE1ct , - Robust Electronics Fuel Level Sensor with EIA-485 communication interface  for application in hazardous area.
For  standard and heavy application.
Vehicle and stationary objects application.
Resolution 1024 or 4096 levels. Available sensor length from 1300 mm and up to 3000 mm.
Operation only with GuardMagic JBB01 (intrinsically safe barrier).
Fuel and Oil level sensor GuardMagic DLLE1ct is intended for fuel level measurement in mobile and stationary tanks, road fuel tanker cargo tanks, fuel storage tanks, fueling station etc.
GuardMagic DLLE1ct operating only together with GuardMagic JBB01 intrinsically safe barrier.
GuardMagic DLLE1ct fuel level sensor is designed with EX equipments requirements.
GuardMagic DLLE1ct fuel level sensor is designed for operation in  the wide temperature range.
Sensor has die cast aluminum case for mechanical protection.
GuardMagic DLLE1ct sensor use the capacitive technology and has not any moving parts.
Advantages:
- Standard and heavy application
- Operation in wide temperature range
- "0" zone application
- Anti vandal protection
- Digital communication interface
- High resolution (up to 4096 levels)
- High noise immunity
- Sensors serial connection (multi tank support)
- Operation liquids: from raw oil and up to kerosene
- Self testing
- Strong mounting
MAIN DATA
Power supply:     10 V , powered by GuardMagic JBB-01(Intrinsically Safe Barrier). GuardMagic JBB01 operation voltage 11…36V
Operation principle:   capacitive
Resolution (number of gradation):   1024 or 4096 level
Data Line:   isolated
Power Line:   isolated
Main operation liquids*:  oil, fuel oil, diesel fuel, transformer oil, petrol, kerosene, fuel jet
Communication interface:    EIA-485
Communication speed: 19 200 bit sec
Sensor serial connection:  YES (by GuardMagic JBB01)
Network mode:  YES
Internal data filter:  YES, programmable
Customer sensor programming (setting):  YES
Ingress protection:  IP65
Impact protection:  IK10
Anti vandal housing:  YES, die cast aluminum
Operation mode:  continues
Operation pressure:  atmospheric
Operation temperature: ambient:  -40 ...+80 , liquids: -40 ... +105
Sensor length: 1300mm; 1500mm; 1700mm; 2000mm; 2500mm; 3000mm
Customer sensor cutting: YES
Mounting:  Six bolts M6 or Six screws 5,5
Connector type:  Superseal (Tyco Electronics), plug 4 pin
Connection cable:  All weather. Usage under difficult environment conditions
UF, water, mineral or synthetic oil, petrol, detergents/cleaners/lotions resistance.
Download GuardMagic DLLE1ct leafler =
http://guardmagic.com/01-engl/91e-downl … let-01.pdf
http://guardmagic.com/01-engl/91e-downl … eaflet.jpg
www.guardmagic.com ;
www.tankercontrol.com;
(24/09/2015 14:22:46 отредактировано GuardMagic)
Re: GuardMagic DLLE1ct - robust fuel level sensor for road fuel tanker
sample 1 of sensor installation in road fuel tanker:
  • GuardMagic DLLE1ct - robust fuel level sensor for road fuel tanker
sample 2 of sensor installation in road fuel tanker:
Sample of Fuel loading
(Three fuel compartments)
Sample of Fuel unloading
GuardMagic DLLE1ct
Looks great !!,  approximately how much time the calibration process take us? thinking in a 30klt Road Fuel Tanker [Diesel]
thanks
Spread the AVL- World
(12/03/2016 10:50:38 отредактировано GuardMagic)
small_gprs пишет:
thanks
I think about few hours.
(based on loading graph)
