Teltonika FM3200
Topic: Teltonika FM3200
hello,
what is the SMS COMMAND that i can send to my teltonika FM3200 device to refer it to wialon servers?
Teltonika FM3200
Re: Teltonika FM3200
easy: "username" "space" "password" "space" "setparam" (look at the manual and find the right parameter id) and last but not least the APN.
you also need to set username (extra ID), password (extra ID) and homenetwork.
do you have the manual? if not, did you check with google "teltonika fm3200 user manual"?
more easy it is just to use the software configurator which you can download for free at the teltonika homepage (do you have the link?)
Enjoy
Wolf.
Teltonika FM3200
I have the manual but i do not know which command im confused between FLUSH/SETPARAM commands,  as the command SETPARAM only showing on manual that i can set the IP, so where to put the port and APN?
Teltonika FM3200
seems that you have different manual...
in that i found in my google search it shows on page 39:
9.4 GPRS access and address settings
APN Name (ID=242)
Parameter defines GPRS Access Point Name.
Minimum
value
Maximum
value
Recommended
value Goes with (depends on) parameters Value type
Empty 32 char
string -
GPRS Enable (ID=240)
APN username (ID=243)
APN Password (ID=244)
S8[32]
Parameter defines APN username. In case operator does not use username for login, value
should be empty.
Minimum
value
Maximum
value
Recommended
Empty 6 char
string -
APN Name (ID=242)
APN Password (ID=244) S8[6]
Parameter defines APN password. . In case operator does not use password for login, value
should be empty.
Minimum
value
Maximum
value
Recommended
Empty 6 char
string -
APN Name (ID=242)
APN username (ID=243) S8[
Wolf
Teltonika FM3200
for example my APN name is MOBILY,  and there is no user or password,  and Wialon IP is     193.193.165.165    the port is 20538  so what is the full command i send by SMS to configure the device to link on wialon servers?
Teltonika FM3200
Please ask your Gurtam Salesmanager to forward your request to me, i will send you the right commands than.
Wolf.
Teltonika FM3200
Hi,
Even I am also looking to change the APN by SMS commands for Teltonika 4200.
Regards,
Teltonika FM3200
orosgroup   here you can download configurator file
http://avl1.teltonika.lt/downloads/FM42 … 0.1.42.zip
you can download all documents from this webpage
regards
Teltonika FM3200
Thanks for the info
