Topic: QuecLink GV55 Lite
Hello,
I have GV55 lite, I try change IP, and Port, from ( Queclink_GV55Lite_Manage_Tool_V1.4.01.exe).
But i have wrong msg With COM.
Pls anyone help me how can change IP and Port.
Thank You
Hello,
Thank You
Hi ,
What is the message you get ?
Connect the Data cable ,Open the tool and select the correct COM port ID .
You can find out the COM port ID (no) from your computer's hardware settings .
Alternatively you can SMS the quick start settings command to the tracker's SIM number ,
AT+GTQSS=gv55,apnname,apnuser,apnpass,3,,2,193.193.165.165,20634,192.0.0.0,0,,30,0,0,,FFFF$
(replace your apnname , apnuser and apnpass to suit your operator or leave apnuser and apnpass if authentication is not required )
AT+GTQSS=gv55,apnname,,,3,,2,193.193.165.165,20634,192.0.0.0,0,,30,0,0,,FFFF$
if you do not see any update on Wialon interface , send the command with IP 193.193.165.167 ,
AT+GTQSS=gv55,apnname,,,3,,2,193.193.165.167,20634,192.0.0.0,0,,30,0,0,,FFFF$
then go to id.wialon.net and check if you see your IMMIE number ,
Let me know if you need any further assistance.
manager tool not accept COM port.
You can give me your Email
